What size wrench do I need...
Old Apr 16, 2003 | 06:27 PM
Metal Wulf's Avatar
Metal Wulf
Default What size wrench do I need...
...for the fuel line going into the carb?
I'm making a Sears run tomorrow, going to pick up some new tools :D
Old Apr 16, 2003 | 07:08 PM
72GACRZR's Avatar
72GACRZR
Default Re: What size wrench do I need... (Metal_Wulf)
If it was me, I would by the pack of line wrenches. I think you get 3 or 4 in the most used sizes. They are the almost closed ones.
Old Apr 16, 2003 | 07:13 PM
bigvette1's Avatar
bigvette1
Default Re: What size wrench do I need... (72GACRZR)
Get flare wrenchs as the fitting is brass and will round off fast. It is 5/8" at both ends. Give the fuel pump a squirt of rust blaster to break up corrosion. Torque it too hard and the soft metal of the fuel pump twists. Or hold it with another wrench.
Hint - pull the fuel inlet line "S" hose and plug it with a 3/8" dowel and a hose clamp. When you pull the metal line to the carb the tank of the pump want to fill up again. Better yet, order yourself a new set of "S" hoses and replace them while under there. They are probably brittle.
Old Apr 16, 2003 | 07:21 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: What size wrench do I need... (bigvette1)
thanks guys :cheers:
I was going to get the flare wrench, just wasn't sure what size I needed...
Old Apr 17, 2003 | 12:55 AM
79VetteMike's Avatar
79VetteMike
You need the medium one. :conehead
Old Apr 17, 2003 | 01:07 AM
Metal Wulf's Avatar
Metal Wulf
Default Re: What size wrench do I need... (79VetteMike)
:lol:
To What size wrench do I need...
