Anybody Have
Old Apr 17, 2003 | 09:30 PM
69vette66's Avatar
69vette66
Default Anybody Have
Anyone have a wiring diagram of the Ignition. I need it from the Ignition switch to the coil, to the starter. Thanks Larry :cheers:
Old Apr 17, 2003 | 09:52 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Re: Anybody Have (69vette66)
What are you doing to the car? I recently installed a Unilite and needed to search for wires too.
Old Apr 17, 2003 | 11:01 PM
69vette66's Avatar
69vette66
Default Re: Anybody Have (74 vert)
Well i have installed a mini high tork starter. Of course it only has 2 hookups. 1 for the battery, 1 for start assist. mine old one has 3, so l leave off the coil side, so points wont be hot all the time and burn up. somebody says it should be hooked up as I did have it at one time. but the coil was hot all the time. So I hooked it up again to batt side, hooked up the Battery and smoke flys, so I unhook the batt and the wire, now I have nothing to the coil. Before I did have when the key was on. but I couldnt get fire to the the plugs. all grounds are hooked up. Now I need to trace the wires to find out where they should be going. Thanks Larry :cheers:
Old Apr 18, 2003 | 12:17 AM
74 vert's Avatar
74 vert
Diagrams have been sent to your email.
Hope you get it going.
Old Apr 18, 2003 | 07:12 PM
69vette66's Avatar
69vette66
Thanx Brad for the help. I found the short. and have it rewired. So now i have to wait for the Pertronix to come in. That should get rid of my problems with the coil assist wire. since I dont want a full 12 volts at the coil all the time. I think that would cause me a lot of problems.
:cheers: Larry
To Anybody Have
