aluminum intake advantage?
Old Apr 19, 2003 | 02:02 PM
John2's Avatar
John2
Default aluminum intake advantage?
I need some help on this one. Other than the weight, is there any advantage to an aluminum intake manifold over a stock manifold?
Thanks,
John
[Modified by John2, 7:03 PM 4/19/2003]
Old Apr 19, 2003 | 02:23 PM
The Money Pit's Avatar
The Money Pit
Default Re: aluminum intake advantage? (John2)
Not on a stock engine.If you see 10hp gain you'd be lucky.Now if you,ve changed exhaust,cam,maybe heads you will see the benifits of an intake change.
Old Apr 19, 2003 | 04:27 PM
mvftw's Avatar
mvftw
Looks... :lol:
Old Apr 19, 2003 | 04:52 PM
73 LS-4's Avatar
73 LS-4
The two biggest advantages over cast iron are weight and heat dissipation. Given equal runner length volume and flow characteristics there isn't any performance advantage over cast iron. But aluminum is far easier to port and clean up then cast iron.
:cheers:
Pat Kunz
Old Apr 19, 2003 | 04:53 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Won't an aluminum intake help dissapate heat a little better also? I've always heard that aluminum heads will run cooler, how about the intake?
Old Apr 19, 2003 | 05:03 PM
Love My 72 and 77's Avatar
Love My 72 and 77
There is a differance between manifolds there are dual plane manifolds that work well from low RPM's up. There are also aluminum manifolds that are designed for high RPM performance like Dominator manifolds.
Old Apr 19, 2003 | 06:57 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Typically, aluminum intakes (factory or after market) are designed to be better flowing than their cast iron counterparts. Even if otherwise identical though, the lighter weight and better heat dissipation of the aluminum intake would be an advantage. The lighter aluminum intake is also easier to handle during installation. On the downside, aluminum is more porus and therefore more likely to stain and discolor.
Don't discount the performance benefits of less weight. Individually, aluminum pieces instead of cast iron may not make much of a difference but enough aluminum pieces can add up to a weight reduction that will have noticeable effect on performance.
Old Apr 20, 2003 | 02:10 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
More than one book has been written on intake manifolds John. And no aluminum isn't any better/faster than or make more power than steel/cast iron. It's in the design and modifications.
To add one thing more, stock cast iron intake manifolds aren't all that bad performance wise.
Old Apr 21, 2003 | 10:07 AM
Ganey's Avatar
Ganey
Default Re: aluminum intake advantage? (Vetterodder)
Performance Al. & less wt. rec.! Even Performer 2101 or Weiand Action+ about 12 HP over stock cast iron which is better than stock egr iron.
Even stock hi rise Al. is almost as good as RPM. Performance Al. is rec.!
:cool:
Old Apr 21, 2003 | 05:10 PM
djcwardog's Avatar
djcwardog
Vetterodder's got it right. In general, you will find better flowing designs among the aftermarket products. My problem is that I want to keep the stock hood on my 73 big block - with the fresh air system. I am not sure that I can swap in an aftermarket dual plane without a carb height problem. I have an Edelbrock (Rochester) carb. Anyone done this on a 73?
Thanks!
Old Apr 21, 2003 | 05:28 PM
DaveL82's Avatar
DaveL82
Default Re: aluminum intake advantage? (djcwardog)
When the next intake technology/marketing concept comes around you can also recycle ther old one LOL
Dave
Old Apr 21, 2003 | 06:34 PM
Black Snowman's Avatar
Black Snowman
If you know the measurments of your current setup you can compare them with the specs of an aftermarket intake, or give the specs to the companies and have them look for what would be closest in their inventory, and hopefully get your carb in the same place and get a performance increase.
Another option would be to get your exisiting intake ported. Everything would be in the same place but if done right you'll get a performance boost. Might not be as much as an aftermarket casting but it might be worth it. You could even try porting it yourself and if you mess it up too bad you could still get an aftermarket intake.
To aluminum intake advantage?
