Shaking Idle & Headlight Probelm
Old Apr 20, 2003 | 11:47 AM
Corvette Lady's Avatar
Corvette Lady
Navigator
Default Shaking Idle & Headlight Probelm
I have a 1980 Vette. It was shaking badly when idling in drive. Mechanic replaced driver headlight acuator and relay valves. Shaking stopped. All of a sudden shaking has started again very badly and headlights now will not pop up where they had worked before. Any ideas what may have happened?
Old Apr 20, 2003 | 11:51 AM
73 LS-4's Avatar
73 LS-4
Default Re: Shaking Idle & Headlight Probelm (Corvette Lady)
Sounds like you sprung another vacuum leak, I'd check around the front headlight relays and see if a vacuum line may have come loose. If nothing obvious is seen try listening for a leak with a rubber piece of hose. Sometimes the only way to find the leak is with a vacuum pump though, but lets hope it's something simple.
:cheers:
Pat Kunz
Old Apr 20, 2003 | 11:52 AM
79VetteMike's Avatar
79VetteMike
Default Re: Shaking Idle & Headlight Probelm (73 LS-4)
:iagree: :iagree: :iagree:
Old Apr 20, 2003 | 01:27 PM
tzavaleta's Avatar
tzavaleta
Default Re: Shaking Idle & Headlight Probelm (79VetteMike)
light goes off in my head...
So a vacuum leak can cause Idle problems? Hmm...
-t
Old Apr 20, 2003 | 01:51 PM
flynhi's Avatar
flynhi
Your car is 23 years old. I wouldn't be too surprised if your vacuum hoses are deteriorated to the point of leaking.
To Shaking Idle & Headlight Probelm
