spark plug wires
Old Apr 21, 2003 | 01:03 AM
rcparra's Avatar
rcparra
3rd Gear
Default spark plug wires
I am in the process of rebuilding engine and front suspension,brakes and steering,I am debating if I should run plug wires in there original location or run them over along the valve covers,I appreciate any advice,pros and cons,let me know.Its a 81 vette 350,with upgrades.
Robert :chevy :party:
Old Apr 21, 2003 | 01:09 AM
Rockn-Roll's Avatar
Rockn-Roll
Default Re: spark plug wires (rcparra)
I'm in favor of the original routing. It will require buying the plug wire kit which includes one long piece of wire that you cut to fit, and the plug ends that you will crimp on.
Old Apr 21, 2003 | 01:11 AM
wallyknoch's Avatar
wallyknoch
When you run the wires in the stock location up from underneath with the 90 degree ends the engine looks a lot cleaner and not like a pump jockeys nightmare. Remember you have a Vette and not a beat up Camaro. :D
Old Apr 21, 2003 | 04:40 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: spark plug wires (wallyknoch)
I plan to run mine in the stock location..
Anybody know where I can buy a roll of good wire, so I can cut my own lenghts...??????
Old Apr 21, 2003 | 08:00 AM
Fevre's Avatar
Fevre
Default Re: spark plug wires (Desertdawg)
With a nice wiring loom I like the over the vlave cover look. You can order 'Universal' sets that have the plug boots attached and you cut and crimp on the dist boots. I bought a Summit brand set the vette that where blue and came with a nice crimping tool. I just bought a set of Accel 8mm black wire for my Formula.
Old Apr 21, 2003 | 08:31 AM
Alwyn678's Avatar
Alwyn678
Default Re: spark plug wires (Fevre)
:iagree:
Old Apr 21, 2003 | 09:30 PM
Dk Met Grn 80 L82's Avatar
Dk Met Grn 80 L82
I just did this on my 80. I bought the Delco wires from Ecklers. They all ran in the original locations except the two on each side that go through the engine mounts. On these I ran them as close to original routing and then went around that area but not through the mounts. The wires were real close in length but they made it.
Old Apr 22, 2003 | 12:43 AM
rcparra's Avatar
rcparra
3rd Gear
Okay I guess I need to see some pictures of the engine compartment showing both spark plug wire locations,I had seen some in previous post,and showes some over valve cover with alulinum brackets,Thanks for all the info,I will post some pix of the process of engine ohaul.
Robert :party:
Old Apr 22, 2003 | 10:31 AM
eddadams's Avatar
eddadams
When I ran the wires on my 75 I bought the replacement wires that are pre-cut to the correct size. I don't remember the brand. All I had to do for the ones going under the motor mounts was pull the rubber boot off, slide it through and then put the rubber boot back on. To get the boot off, I soaked it in a glass of hot water for a minute or two to soften it up and the boot slid right off. Good luck.
Old Apr 22, 2003 | 10:39 AM
shotgun_000's Avatar
shotgun_000
Here ya go. My engine doesn't look that great, but it works well
I'm not a fan of the factory routing. But, this routing to me is easier when you have headers. :cheers:
Old Apr 22, 2003 | 10:42 AM
Alwyn678's Avatar
Alwyn678
Default Re: spark plug wires (shotgun_000)
Here are some pics using the looms
Old Apr 22, 2003 | 10:52 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I bought Accell from mid america. Routed them in the original route and they fit perfectly. I was lucky however, I have access to a lift. Made the job far easier. :smash:
Old Apr 22, 2003 | 12:04 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Re: spark plug wires (Avette4me)
Any pics of wire sets when using smog headers with the air tubes on top? I have Hedman 68301 Headers.
Old Apr 22, 2003 | 01:30 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: spark plug wires (SanDiegoPaul)
I don't remember who's set it was, but I've seen both "vertical" and "horizontal" over the valve cover looms, what's the difference here? Well I guess the difference is clear, but does anyone have pictures of the two different types? Thanks.
-Chris
Old Apr 22, 2003 | 01:59 PM
flood's Avatar
flood
Default Re: spark plug wires (RUXperienced)
I guess it would also depend on Radio Interference. I would still route them in the original location. Just looks different and thats the way it came :cheers:
Old Apr 22, 2003 | 02:32 PM
BTZ WKN's Avatar
BTZ WKN
Cruising
I have a 73 (350 cu in.). When I purchased it, the prev owner had just done a tune up, but didn't install the correct wires. He had insted run a set of generic wires over the valve covers. I drove the car home (about 15 miles), and the heat from the engine caught the wires on fire. Luckily I caught it in time.
Old Apr 22, 2003 | 08:45 PM
Red73's Avatar
Red73
Default Re: spark plug wires (BTZ WKN)
Old Apr 22, 2003 | 09:02 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
I like my Moroso looms. They can be configured several different ways and I'm never had a burnt wire or boot.
To spark plug wires
