What size bolt for rear spring mounts?
Old Apr 21, 2003 | 11:07 AM
lvrpool32's Avatar
lvrpool32
Default What size bolt for rear spring mounts?
All,
I want to lower the rear of th ecar and I believe I just need to install longer bolts, say 10".
Can someone tell me what size and thread they are (ie 9/16" or whatever)
thanx
Nick
Old Apr 21, 2003 | 11:26 AM
BB wowbagger's Avatar
BB wowbagger
Default Re: What size bolt for rear spring mounts? (lvrpool32)
I belive they are 9/16s.VPB have a kit for those bolts.Buy real heavyduty bolts,theres alot of weight on these ones..
:cheers: :cheers:
Old Apr 21, 2003 | 11:47 AM
TedH's Avatar
TedH
If you don't get your answer here, you can send an inquiry to Van Steel at http://www.vansteel.com and they will send you a prompt reply.
The stock length bolts are $9 each. The long bolts can be 8" or 10" in length (depends on how low you want to go).
I sold a set of these long bolts with washers and lock nuts used for $10 just a few months ago. Van Steel sells the long bolts priced at $22 each so you can see that they have to be high quality (I suspect some mark-up though).
[Modified by TedH, 11:49 AM 4/21/2003]
Old Apr 21, 2003 | 04:40 PM
Pedro'74's Avatar
Pedro'74
Default Re: What size bolt for rear spring mounts? (TedH)
I believe the end bolts are 1/2" coarse thread, but I'm not completely sure. The center bolts (to diff cover) are 9/16".
-Pedro
EDIT: Nah, come to think of it, I'm almost sure the end link bolts are 9/16" too.
[Modified by Pedro'74, 7:02 PM 4/21/2003]
To What size bolt for rear spring mounts?
