C3 aftermarket Stereo
Old Apr 21, 2003 | 09:42 PM
7SILVER8's Avatar
7SILVER8
Default C3 aftermarket Stereo
Has anyone put a after market stereo into a 1978 or similar Vette?? If so, which brands will fit? Thanks!! :flag
Old Apr 21, 2003 | 09:46 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: C3 aftermarket Stereo (7SILVER8)
My car came already modified for a DIN (non shaft style, the most common) radio. I initially had a Clarion. Then I replaced it with two Pioneers in two days. Each had a catastrophic failure and was returned. Then I bought a JVC, which has been in there since last week. I really like it. Nice tunes, even without an aftermarket amp (and all the noise that invariably goes with it).
The JVC can display upto 1600 colors and even photos (?). It also plays MP3 discs, so I can play a single disc containing 170+ songs.
The speakers are 4x6 Kenwoods in front and 6x9 Pioneers in the rear.
:cheers:
Old Apr 21, 2003 | 09:50 PM
Metal Wulf's Avatar
Metal Wulf
any single din radio will fit, just need to cut the bezel or buy one that's already cut :cheers:
Old Apr 21, 2003 | 09:57 PM
Crash Dummy's Avatar
Crash Dummy
There are aftermarket stereos that will fit right into your bezel without cutting from almost all of the vette suppliers. I have a Kenwood KRC-2007 in mine and Alpine Amp/Speakers in the rear. Many have pointed it out before that bezels are not expensive, so chop away if you want and put in what you want. If anyone wants to go back to originial, the bezels are available.
Old Apr 21, 2003 | 10:02 PM
7SILVER8's Avatar
7SILVER8
Default Re: C3 aftermarket Stereo (bgrice)
That's true.....Thanks. I was thinking of putting the Kenwood 2007 in, but was wondering if there was any others out there. Thanks again!! :flag
Old Apr 21, 2003 | 10:20 PM
page62's Avatar
page62
Just take out your Dremel and start cutting! That's what I did...and it looks right somehow...
[Modified by page62, 9:20 PM 4/21/2003]
Old Apr 21, 2003 | 10:25 PM
7SILVER8's Avatar
7SILVER8
Default Re: C3 aftermarket Stereo (page62)
Cool! I was also worried about room for the stereo. Was there plenty of room to put that stereo in, or was it pretty tight? :flag
Old Apr 21, 2003 | 10:30 PM
Metal Wulf's Avatar
Metal Wulf
there's plenty of room in my '78
Old Apr 21, 2003 | 10:40 PM
Wrencher's Avatar
Wrencher
There's plenty of room, as the originals are much larger than the aftermarket DIN units. If your bezel is original and not beat up, I'd save it and use an aftermarket bezel or an E-bay cut-up one. The originals are better quality and, hey, its original! Mine was already broke at the A/C vent, so no problem cutting it for my Blaupunkt Santa Monica. I used some kenwood 4x6's in front and 6" rounds in boxes with velcro in back.
Hans
Old Apr 21, 2003 | 10:51 PM
Rich80's Avatar
Rich80
http://www.boomspeed.com/rich80/Im001365.jpg
Just mounted it this weekend.
Old Apr 21, 2003 | 11:06 PM
Crash Dummy
There are definitely better stereos than the Kenwoods. But, I am guessing you probably already know that. If I had it all to do again I would probably not have went the way I did as it seems the unit has a hard time pushing the amp and speakers.
Then again... anyone who puts a decent stereo in a vert with sidepipes is somewhat coo-coo.
Old Apr 22, 2003 | 02:12 AM
Northwest79's Avatar
Northwest79
when cutting your hole, cut it as low as possible without breaking the bezel and/or having bad structural integrity.
If in the future you decide to go for an amplifier as well, you will probably use RCA connecters into the back of the stereo, the newer stereo's plug these directly into the back of the stereo (as opposed to having wires with plugs) ..
This has the effect of lengthening the head unit, and causing some minor
issues with fit in the back and you will be forced to angle the unit at a slightly
more drastic angle causing the face plate to not quite sit flush...
If you are using the head unit's speaker wire outputs.. then you can fold them over and there are no issues...
:cheers:
Chris
Old Apr 22, 2003 | 09:49 AM
vettedan's Avatar
vettedan
I have a Blaupunkt Honolulu CD player. '77 and up is a bit easier because of the redesigned console will accept a variety of radios due to the deeper design. You will need to modify the hole to get the DIN to fit. Check your local auto stereo installer. They should have all the goodies you will need.
Dan
To C3 aftermarket Stereo
