Paging Bence13_33
Old Apr 21, 2003 | 10:44 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Paging Bence13_33
Hey Shane,
I was just wondering about a few things on your car... What rims are you using.. If you still use the stock Rallies - you can get a .1 to .2 faster ET just by swapping to Centerline Auto Drag or other light weight rims.. The rally wheels are around 24lbs/rim.. The Centerlines are 14.5 lbs/rim.. That's almost 10 lbs per rim lighter.. Due to the fact that it's centrifugal weight - each 10 lbs that you take off is worth about 50lbs... which would make your car effectively 100 - 200 lbs lighter... which could take .1 to .2 off your ET..
There are some additional weight savings that can reduce your ET by quite a bit.. One example is the spare tire carrier and spare tire (if you have it)..
:cheers:
Olivier
Old Apr 21, 2003 | 10:50 PM
bence13_33's Avatar
bence13_33
Default Re: Paging Bence13_33 (GrandSportC3)
Olivier:
I have currently already removed the spare tire, carrier and floor jack from my car. I am however still running stock Corvette Rally rims. I may have to look into a set of Centerline Auto Drag Rims. Thanks for the recommendation!
Old Apr 21, 2003 | 10:54 PM
GrandSportC3
Default Re: Paging Bence13_33 (bence13_33)
Olivier:
The Convo Pro's are pretty light too.. You can pick up a set of Auto Drags for around $200 - $250 on Ebay...
Stingy74's Avatar
Stingy74
Olivier:
Some Auto Drag's or Convo Pro's in a 15x8 with 4.5" backspace would fit pretty good :yesnod: .
Old Apr 21, 2003 | 11:04 PM
GrandSportC3
Default Re: Paging Bence13_33 (Stingy74)
Olivier:
I don't think that you can get them with 4.5" backspacing.. My Auto Drags have 3.375 inch backspacing and don't stick out.. However - I have 1 inch flares on all 4 wheels...
Old Apr 21, 2003 | 11:10 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Bence....
What are those drag radials you are running again? They fit right on the stock rally rims?
Old Apr 21, 2003 | 11:11 PM
GrandSportC3
Default Re: Paging Bence13_33 (bgrice)
Bence....
He uses ET Streets which aren't Drag Radials.. They are actually knit tires just like slicks..
To Paging Bence13_33
