Rag Joint Question
Old Apr 22, 2003 | 04:54 PM
majbillgsd's Avatar
majbillgsd
Default Rag Joint Question
Is it best to replace a rag joint with a new rag joint or can I use metal to metal replacement? Seems somewhere I saw a setup that uses a swivel replacement but then that could have been associated with rack and pinion system that you can now obtain for a C3.
Thanks,
Bill
:confused:
We support our troops in TN/KY :flag
Old Apr 22, 2003 | 05:12 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: Rag Joint Question (majbillgsd)
Jim Shea just commented on this. Someone posted pictures of what you described. The metal joint will work, but because it is a solid joint, it will overly stress the connections. The ragjoint is used as an isolator. If you use it, you'll have problems.
