Vents in rear
Old Apr 22, 2003 | 10:15 PM
bbeck's Avatar
bbeck
Default Vents in rear
Can anyone tell me how the vents in the rear deck are supposed to function? Mine allows water inside whenever I wash the car, or it rains. There is a vaccuum line that runs to it, not sure how it works- on the driver side. Then in the center, looks as if something has been removed, as there is four holes drilled, with what looks like a square shaped object missing. Anyone have any pics of how this setup looks. Any diagrams how it works?
Old Apr 22, 2003 | 11:06 PM
72GACRZR's Avatar
72GACRZR
Default Re: Vents in rear (bbeck)
The water is coming in because you have a pluged drain hoses . The run out the side down behind the wheels, I think. I don't have them on my vert with ac
Just found this
http://forums.corvetteforum.com/zerothread?id=457552.
[Modified by 72GACRZR, 11:06 PM 4/22/2003]
[Modified by 72GACRZR, 11:09 PM 4/22/2003]
Old Apr 23, 2003 | 05:37 AM
Larry B.'s Avatar
Larry B.
Default Re: Vents in rear (72GACRZR)
The rubber drains get rotten and then leak. Only factory non-A/C cars have functional vents.
Old Apr 23, 2003 | 03:40 PM
Surfer69's Avatar
Surfer69
another thread on same topic, " Astro Vents"
To Vents in rear
