Front End Too High
Old Apr 24, 2003 | 12:06 PM
Edzred72's Avatar
Edzred72
Default Front End Too High
NO...I'm not pouring wacky weed into my engine bay.....Ever since I installed Energy Suspension Poly front swaybar bushings on the 77, my front end is about 3/4" higher than the rear. Is there a longer sway bar link bolt (similar to rear spring link) available? Or must I go back to rubber bushings till the rest of the front suspension catches up with poly bushings.
Eddie :cheers: :cheers:
Old Apr 24, 2003 | 12:17 PM
Zack Wenning's Avatar
Zack Wenning
Default Re: Front End Too High (Silvr77)
I had to cut the springs in the front. I put new 460" springs in and it simply sat too high, even before I put the smaller diameter front tires on. Ive cut 3/4 of a coil off and I am now considering cutting more.
Sorry, just reread your post, I would stick with the poly on the swaybar. Have you given everything a chance to settle?
[Modified by Zack Wenning, 12:21 PM 4/24/2003]
Old Apr 24, 2003 | 12:38 PM
Scooter70's Avatar
Scooter70
Default Re: Front End Too High (Zack Wenning)
I just cut my front springs too, but to answer your question... was your car down on its wheels before you torqued down all of the bolts? If the car was up on jackstands with the wheels drooping, then the bushings won't let the car settle to the right rideheight. Try to do the final torquing with the car up on ramps so you can get underneath.
Hope that helps.
Old Apr 24, 2003 | 06:04 PM
BB73Chris's Avatar
BB73Chris
PAW catalog, page 70, 510ci Big Block Chevy... the front end will sit lower :yesnod:
Old Apr 24, 2003 | 06:37 PM
terryrudy's Avatar
terryrudy
Wow, would sway bar bushings cause it raise up in front? Doesn't seem like it would. . .
In any case I went with 550# front springs and am pleased with them. They lowered the front perfect (now a tad bit higher since I swapped in the aluminum heads). Most of the driver's road harshness seems to be attributed to the rear spring than the front spring IMO. Got any pics to see the diff in height?
good luck!
-terry
To Front End Too High
