Help Identify where this goes.. please
Old Apr 24, 2003 | 07:57 PM
Koz
Guest
Posts: n/a
Default Help Identify where this goes.. please
I got done replaceing everything I took off and I have this one piece left over. I believe it came off under the drivers side someplace but I just can't figure out where it goes. Any ideas.. Thanks
http://www.corvetteforum.net/c3/koz/...n/unknown1.jpg http://www.corvetteforum.net/c3/koz/...n/unknown2.jpg http://www.corvetteforum.net/c3/koz/...n/unknown3.jpg http://www.corvetteforum.net/c3/koz/...n/unknown4.jpg http://www.corvetteforum.net/c3/koz/...n/unknown5.jpg
Old Apr 24, 2003 | 08:00 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Help Identify where this goes.. please (Koz)
In this picture the top hole looks like it was ment to mount to the same bolts that holds a valve cover in place.
Is it a heat shield for something ??
I have never seen a part like that on my 1980.
Old Apr 24, 2003 | 08:13 PM
Black Snowman's Avatar
Black Snowman
Default Re: Help Identify where this goes.. please (BSeery)
Looks like a heat shield to me too. For the starter maybe? I'd follow the exhaust track and look for places it could fit.
Old Apr 24, 2003 | 09:08 PM
killain's Avatar
killain
Oldtimer
I think that is the heat shield that protects the starter wires !
Old Apr 24, 2003 | 10:58 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Help Identify where this goes.. please (killain)
I think I know where it goes. I removed a peice like that on my 80. Driverside, REAR, around the battery compartment. If I am not mistaken, it protects the battery cables.
Old Apr 25, 2003 | 12:13 AM
454Can-Am's Avatar
454Can-Am
Default Re: Help Identify where this goes.. please (71,454,4spd)
I agree with 71,454,4spd ----- it bolts to the frame under the parking brake bracket and then to the bottom of the car (under the battery)
:iagree:
Old Apr 25, 2003 | 01:11 AM
mapman's Avatar
mapman
:iagree: Protects the battery charge cable that runs back to the battery from the alternator (also a ground cable). You may also want to check the insulation on the cables to make sure they are in good condition. A little copper anti-seize on that part where it bolts up to the frame will lessen corrosion (aluminum and steel).
Old Apr 25, 2003 | 03:27 AM
Twin_Turbo's Avatar
Twin_Turbo
:iagree:
I agree, that's it but I don't think it's supposed to be bent like that, mine was reasonably flat
[Modified by Twin_Turbo, 2:29 AM 4/25/2003]
Old Apr 25, 2003 | 09:49 AM
Koz
Guest
Posts: n/a
Default Re: Help Identify where this goes.. please (Twin_Turbo)
I tried several places and nothing seemed to mate up with the holes. Can someone who has this installed on thier car provide a picture. It makes sense what everyone is saying but I can't see anywhere the small whole will bolt to..
Old Apr 25, 2003 | 11:59 PM
LAvetteman's Avatar
LAvetteman
I"ll try to post a pic tommorrow.
Old Apr 28, 2003 | 09:39 AM
Koz
Guest
Posts: n/a
Thanks..
Old Apr 28, 2003 | 12:18 PM
Richard Cooper's Avatar
Richard Cooper
Koz, it goes under the drivers side and protects the battery wires. Right underthe battery compartment. Just put the one back on my 81 yesterday. :thumbs:
Old Apr 28, 2003 | 12:57 PM
Koz
Guest
Posts: n/a
Default Re: Help Identify where this goes.. please (Richard Cooper)
THANKS!!! Can you post a picture. What did you bolt it to?
I just went back under there and I can't figure it out. The little hole on the side has nothing to bolt to no matter where I put it. Please post a picture.. Thanks..
[Modified by Koz, 1:31 PM 4/28/2003]
Old Apr 28, 2003 | 01:56 PM
mapman's Avatar
mapman
Small hole bolts to the frame (crossmember), large hole bolts to the underside of the compartment that holds the battery. The backside of the aluminum plate, where it bolts to the frame, may have deteriorated from corrosion caused by galvanic action between the aluminum and the steel frame.
If you first (loosely) attach the aluminum guard to the bottom of the battery box, and then put the small hole on the frame crossmember, I think you will see where the hole lines up with the bolt hole in the frame.
Old Apr 28, 2003 | 02:42 PM
Koz
Guest
Posts: n/a
Default Re: Help Identify where this goes.. please (mapman)
:party: Got it.. Damm do I feel stupid.. :banghead:
I was looking at where the ground wires connect to the cross member and trying to protect them.. It fits nice when you put it where it goes.. Thanks to everyone for your help.. :cheers: :cheers:
To Help Identify where this goes.. please
