Door PinSwitches
Old Apr 25, 2003 | 04:23 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Door PinSwitches
I am looking for replacements on the OEM alarm and also courtesy light Pin Switches for the doors of my '76.
Anyone out there ever bought 'em new? :flag
Old Apr 25, 2003 | 04:28 PM
rreavis's Avatar
rreavis
Default Re: Door PinSwitches (SanDiegoPaul)
I purchased the Pin Switches in the doors about 10 years ago from Ecklers..
Just checked and they are 9.99. Part# A9575
Sorry, you did say 76.. Part# A9576 and 3.50 each.... That is much better
[Modified by rreavis, 3:30 PM 4/25/2003]
Old Apr 25, 2003 | 04:36 PM
SanDiegoPaul
Default Re: Door PinSwitches (rreavis)
Thanks Mucho. Now, identification. There are long, post-style pin switches at the front, near the hinges. These I think are for the courtesy lights.
Then at the bottom of the door, to the rear of the car is another much shorter switch with out the post style mounting. And on both doors they have rivets on either side of the switch, even though the switches look like they just unscrew with a 7/16 wrench. :eek:
Are they screwed into a metal piece that is riveted to the Glass body? And are these rear switches the ones for the factory alarm? :hat
Old Apr 25, 2003 | 04:44 PM
sb69coupe's Avatar
sb69coupe
Yes, the switches at the rear of the jamb are for the door ajar light and the alarm. They screw into a metal plate that's riveted to the fiberglass.
Shannon
Old Apr 25, 2003 | 04:49 PM
rreavis's Avatar
rreavis
Default Re: Door PinSwitches (sb69coupe)
Shannon
:iagree:
Old Apr 25, 2003 | 05:12 PM
SanDiegoPaul
Kewel! Then I don't have to worry about ever-so-gently trying to get them out and find out that it looks like BUBBA was there later.
Thanks guys! :seeya :chevy
Old Apr 26, 2003 | 01:32 AM
Cali,68,L-79's Avatar
Cali,68,L-79
Paul call me first!!!!!!! I have some !!!!
Old Apr 26, 2003 | 10:09 AM
no_radio's Avatar
no_radio
Default Re: Door PinSwitches (Cali,77,L-82)
Has anyone ever had to repair the metal plate? The threads are in a poor condition on mine, and I can't keep the door switch from coming loose. Cause the Door Ajar light to flash intermittently, or stay on sometimes.
I tried cleaning up the threads but the metal is thin and of poor quality.
Thanks,
Jeff
Old Apr 26, 2003 | 10:14 AM
SanDiegoPaul
What should I call you??
I'll see ya at the run today.
Old Apr 26, 2003 | 10:35 AM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
In case anyone else needs them the door switch part number is GM #9662505 and they cost me $4.31 each yesterday. :seeya Jim
Old Apr 26, 2003 | 10:46 AM
SanDiegoPaul
Default Re: Door PinSwitches (PROSOUTH)
Is that the long ones at the front of door or the short ones at the rear?
Old Apr 26, 2003 | 12:12 PM
PROSOUTH's Avatar
PROSOUTH
St. Jude Donor '05
Here they all are, take your application and applyit to your need. Jim
11.950 SWITCH, DOME LAMP DOOR JAMB
68-75 #3928753 Courtesy lamp & Key
68-72 #3929804 Dr ajar warning lamp
69-74 #3929804 Hood open warning
73-76 #6258295 Dr ajar warning lamp
75-76 #6258295 Dr ajar warning lamp
75-78 #9662504 LH Front door jamb
75-76 #9662505 LH Courtesy lamp & Key warning
75-81 #9662506 RH Courtesy lamp
77-81 #459391 Door ajar warning lamp
Old Apr 26, 2003 | 09:39 PM
SanDiegoPaul
Muchas Gracias
As we say in Greek. :lolg:
Old Apr 27, 2003 | 12:55 AM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: Door PinSwitches (no_radio)
Thanks,
Jeff
The metal is actually thick. When I broke my switches loose, I actually broke both rivets on one of them and it fell down in the door jamb area after I got the switch out. All I can say is to be careful with the metal mounting plate. I think your door ajar flashing is coming from somewhere else, as the plate is not connected to anything else that is metal.....it's not the ground, the black wire is. The metal plate is simply a mounting point for the switch.
AC
To Door PinSwitches
