How to replace A/C harness without major surgery?
Old Apr 26, 2003 | 12:31 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default How to replace A/C harness without major surgery?
After rebuilding heater box and replacing with ductwork - discoverd A/C harness routs behind and tight fit. Old wire harness too crisp. Can I rout new wire harness through with string or maybe an old dipstick? Yes, desperation has set in. I dread removing all that ductwork again. :(
Also what can I replace that firewall grommet with? None of the parts cataloges list it. :confused:
Old Apr 26, 2003 | 07:02 PM
cardo0's Avatar
cardo0
Default Re: How to replace A/C harness without major surgery? (cardo0)
ttt Try again.
Old Apr 27, 2003 | 01:24 PM
cardo0's Avatar
cardo0
ttt and again.
Old May 2, 2003 | 12:55 AM
NTMMD8R's Avatar
NTMMD8R
I did that surgery about 2 years ago. I bought a new harness and it came with a grommet. I had the right side dash pad off, and the center console out, and the gauge cluster hanging there. I used a transmission dip stick to pull the harness from the inside to the outside. The hardest part was getting that grommet seated. My wife was inside with a long large screwdriver pushing on the grommet while I was on the outside pulling on the harness. It wasn't easy, but it did fit...yes it was a tight fit. You about have to have someone working to help you, and it helps to spray some silicone on the grommet when you try to seat it. I hope this helps. :smash:
Old May 2, 2003 | 07:52 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Try these people for the A/C harness, but ask to be sure it comes with that big grommet. http://www.lectriclimited.com/ I don't think they will sell the grommet without the harness
You should be able to get it started in the hole because the end is small, but seating it will be a tug-of-war. Apply a little rubber lube like the stuff used by plumbers for soil pipe rubber seals, "ty-seal lubricant" should help it to slide nice.
To How to replace A/C harness without major surgery?
