Air leak inside the car !
Old Apr 26, 2003 | 09:19 AM
dman535's Avatar
dman535
Default Air leak inside the car !
I was driving on the freeway last night and it was cold out. Tops on, windows up. I could feel cold air rushing into the car. Id I put my hand just to the right of the shifter I could feel a steady blast. Any ideas on where to look to remedy that ?
Old Apr 26, 2003 | 05:56 PM
phoenix's Avatar
phoenix
Default Re: Air leak inside the car ! (dman535)
It could be a number of places. I had a gap in the firewall to body seal on the passenger side. This let engine air into the car through the recirc duct at the passenger kick panel. After looking, I had the same gap on the drivers side too.
Here is a picture of what I am talking about.
I'm sure that it could be other things too, but this was my problem. I am installing vintage air, so I am sealing everything up. :)
[Modified by phoenix, 5:57 PM 4/26/2003]
Old Apr 27, 2003 | 12:59 AM
Greg's Avatar
Greg
Just another Corvette guy
Default Re: Air leak inside the car ! (phoenix)
Hey Derek,
I think Mike actually pulled his engine just to show you that hole down there. Does this forum have the best help a guy could ask for, or what?
:party:
Old Apr 27, 2003 | 02:34 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Air leak inside the car ! (Greg)
I think your picture needed a little more detail.
Hope this helps. :cheers:
Old Apr 27, 2003 | 03:58 AM
Doc Rebuild's Avatar
Doc Rebuild
There could be several sources. However, in the area of the console, I would first suspect a torn or degraded lower shift boot on a 4 speed or the similarly functioning round rubber seal on an automatic shifter cable. The rubber seal on the edges of the foot well fresh air vent doors could be suspect. A separation may occur in thew bond between the fiberglass firewall panel and the underbody panel. Or a crack or damage to one of these panels. My L89 has floor board cracks from power shifting. All the cables, hoses and wires passing through the firewall are sealed with grommets and a black tar like sealer. The heater may leak air even when theoretically poopie off. Or the heater boxes may not be properly seated on the firewall or be damaged. On AC models the plenum actuators may nor be closing outside air vent doors. Any and all could leak air. Get the appropriate model year factory assembly manual for assistance.
Geoffrey Coenen
NCRS #2473
NCM Lifetime #105
Precision Valley Corvette Museum Charter Member #20 (I think)
Vettehead #18-1
Retired #1 56, 63, 67, 68, 68, 69, 75, 99 and I want more! :D
Old Apr 27, 2003 | 07:36 PM
phoenix's Avatar
phoenix
Default Re: Air leak inside the car ! (Desertdawg)
Yup... you just about summed it up. :D:D :cheers:
BTW... engine is back in as of today. :)
Old Apr 28, 2003 | 01:50 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
If you post a picture of your installed engine. I promise to not photochop it. :D
To Air leak inside the car !
