Electrical Connector question
Old Apr 26, 2003 | 12:47 PM
rreavis's Avatar
rreavis
Default Electrical Connector question
I know that most all Electrical connectors can be dis-assembled.
Does anyone out there know how to take this thing apart..
It has like a red cross in the middle and is a 4 pin connector.
It is the Fuel Pump Plug from my Motor Home.
Sorry, it is actually a Ford plug.
My appoligies up front as this is not from my C3 .... Did the "ford" above give that away ?
http://www.employees.org/~rreavis/topview.jpg
This was a cool bug even if it is a Ford......
While riding down the road the engine dies. Sometimed it will not start.
Fuel Pressure guage says 0.. Wire going to Pump, before above plug reads 12v.
Found that if I played with the Plug on top of the tank, the pump would run again.
Dropped 50gall tank and find that Black wire in plug opens as you move it around. That is why I need to know how to dis-assembly plug..
May just go buy another 4 pin style... Maybe a Chevy plug...
Thanks,
[Modified by rreavis, 11:49 AM 4/26/2003]
[Modified by rreavis, 12:00 PM 4/26/2003]
