Checking Vaccum
Old Apr 26, 2003 | 01:34 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Checking Vaccum
I was checking to see how much engine vaccum I have at idle and the needle on the gauge bounces about 2 to 3 pounds. What could cause this. I have read elsewhere that it could be running to rich or to lean. Hopefully that is all there is to it. I do have a slight stumble sometimes when just touching the gas while cruising at slow speed.
Thanks for any help.
Old Apr 26, 2003 | 05:06 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Re: Checking Vaccum (Eddie 70)
Hmmm. If it is indeed vacuum you're talking about that's measured in inches. Now, a flutter of 2-3 inches of vacuum is not severe, but not good. It indicates valve issues. How many miles on the motor?
Old Apr 26, 2003 | 08:15 PM
Nomad78SA's Avatar
Nomad78SA
Default Re: Checking Vaccum (SanDiegoPaul)
Mind explaining just how you checked the vacuum and where you hooked too and ect.. is it bouncing 2-3 inches from a set value like 15 to 18 inches?
Neil in Tenn
[Modified by Nomad78SA, 7:17 PM 4/26/2003]
Old Apr 26, 2003 | 11:29 PM
Eddie 70's Avatar
Eddie 70
Default Re: Checking Vaccum (Nomad78SA)
I checked the vaccum at the full vaccum port at the front of my Holley Street Avenger. It is just flutter between like 14 to 16 inches at 650RPM.
Old Apr 26, 2003 | 11:37 PM
Greg's Avatar
Greg
Just another Corvette guy
Hey Eddie,
18-20 inches of vacuum is ideal for a stock set up, but from the looks of the intake and other mods to that stove, 14-16 is pretty good. A two inch bounce wouldn't concern me.
Greg
To Checking Vaccum
