Somebody Quick before I Snap a bolt??????
Old Apr 26, 2003 | 08:38 PM
8T1-7T9 BIONIC VETTE's Avatar
Default Somebody Quick before I Snap a bolt??????
The bolt that goes on the harmonic balancer into the crank.....Is this a righty tighty.....lefty loosey......or righty loosey...lefty tighty? :flag :seeya Cappy
Old Apr 26, 2003 | 08:40 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Re: Somebody Quick before I Snap a bolt?????? (8T1-7T9 BIONIC VETTE)
It is a standard right hand threaded bolt like all others on the Vette.
Old Apr 26, 2003 | 08:43 PM
Default Re: Somebody Quick before I Snap a bolt?????? (SanDiegoPaul)
Thanks Paul....
I was banging away at it.....and it does not want to budge....Didn't want to snap it.....I knew one of the forum guys would know for sure. :seeya :flag Cappy
Old Apr 26, 2003 | 08:48 PM
SanDiegoPaul
The way I have removed them is using a breaker bar and the engine's starter. Believe it or not it 's an old trick. :yesnod:
Remember the direction of engine rotation is clockwise from the front. Put a breaker bar on the bolt, and leave the handle of the bar about an inch or so from the frame or something solid.
Pull power off the ign coil and bump the starter. It will come off. Or if you have a flywheel tool you can wedge it in there by the flywheel and armwrestle it up top. But the starter will loosen it for you. What you need is that one quick jerk - just like an impact wrench does.
Old Apr 26, 2003 | 09:05 PM
Thanks Paul......
I have the engine out on an engine stand.....everything is off the engine except the crank...and the cam.
Pulling the Beck Racing 383 Max Velocity Plus Engine apart...appears the only good stuff left in there is the block.....the rest is trashed.....
The oil pick up broke off and there was no oil to the engine....hence zero pressure....It didn't run long like this since I stopped running the engine as soon as pressure went to zero.....however I don't trust anything in there....the oil pickup was welded on.....It broke right at the weld point....then I guess the crank caught it and mangle it from the support bracket....hence the noise I heard....I may bore out to .40 over and go with all forged rotating assembly......Thanks again for the tip... :flag :seeya Cappy
Old Apr 26, 2003 | 09:22 PM
QuickVet's Avatar
QuickVet
dont break the bolt in that bill mitchell crank :smash: :D
Old Apr 26, 2003 | 10:56 PM
Default Re: Somebody Quick before I Snap a bolt?????? (QuickVet)
Me no touchy the Bill Mitchell unless professional mechanic standing by.....
I do have a question about the crank...How can I tell it's a forged or cast????
When I banged on it with hammer it rang like a bell..... :eek: :D
Old Apr 26, 2003 | 11:16 PM
QuickVet's Avatar
QuickVet
:lol: dont know how you can tell. i would find out the manufacture and ask them :p:
Old Apr 27, 2003 | 02:11 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
They will all ring like a bell, Call teh manufacture.
To Somebody Quick before I Snap a bolt??????
