Gen. VI mechanical fuel pump question
Old Apr 26, 2003 | 09:22 PM
ORVette's Avatar
ORVette
Default Gen. VI mechanical fuel pump question
I am running the 71-74 correct BB mechanical fuel pump I got from Paragon, and it's making a lot of noise. I don't think it's the pump itself, but it sounds like maybe the pump rod is short and is slapping against the pump arm. Sounds like a lifter tick. I pulled the pump off the block and ran it, no noise. I tried using no gasket, but there is still noise. I compared the pump rod to a new one and they are identical. Any ideas?????
Old Apr 26, 2003 | 10:00 PM
goinbroke's Avatar
goinbroke
Default Re: Gen. VI mechanical fuel pump question (ORVette)
I just went through the same problem on a small block. Turned out it was the fuel pump itself. After I bought the replacement pump I compared the two pump arms. The new one had an arm with a noticeably longer reach (distance from the mounting wall). I'm guessing the tick I was hearing was the arm hitting it's max travel on the upstroke. Anyway, the new pump fixed the problem. I've also heard that a weak return spring will create clicks from a fuel pump.
[Modified by goinbroke, 9:01 PM 4/26/2003]
Old Apr 26, 2003 | 10:16 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Re: Gen. VI mechanical fuel pump question (goinbroke)
:iagree:
It is a bad pump. New or not, it's bad.
To Gen. VI mechanical fuel pump question
