Create you own build sheet - Custom!
Old Apr 27, 2003 | 02:36 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Create you own build sheet - Custom!
Check this website out: look on the right side of the page and you will see where you can create your own build sheet for any year. Cool! :yesnod:
http://corvetteparts.com
Old Apr 27, 2003 | 02:50 PM
Double Aught's Avatar
Double Aught
Default Re: Create you own build sheet - Custom! (SanDiegoPaul)
Thanks Paul, I just bookmarked it for later viewing. BTW, my carb is acting up. The idle is surging when in gear and almost stalled on me yesterday coming back from the gym. I pulled into my carport, held the brake and observed the tach. The idle went from 800 down to 400 and every point in between. Almost stalled, too. Out of gear, idles normal. Any thoughts on what it might be?
Old Apr 27, 2003 | 03:15 PM
SanDiegoPaul
Default Re: Create you own build sheet - Custom! (sd pacecar)
Does it have a throttle kicker on it to raise the idle when the A/C is on, or the other type that is just a dashpot-type device that keeps the throttle plates from snapping shut too quickly? If so then check these things. Other than that I'd check float level, replace the fuel filter, and clean out any dirt that may be in the float bowls that got past the filter.
What is the carb's history? Is it an OEM Q-Jet or an Edlebrock model?
Old Apr 27, 2003 | 03:19 PM
QuickVet's Avatar
QuickVet
That is pretty neat :)
Old Apr 27, 2003 | 03:54 PM
Double Aught
It is the original carb and I had it rebuilt about a year ago. I let the fuel tank run way down and the pump sucked up allot of the crud at the bottom. That consquently got into the carb. I checked the filter yesterday and it was clean. It doesn't have the AC throttle kicker. Not sure about the other item you mentioned.
[Modified by sd pacecar, 12:54 PM 4/27/2003]
Old Apr 27, 2003 | 04:10 PM
battsup's Avatar
battsup
That's sweet, does anybody know of a website that has the prices for the options listed? I already checked out the www.idavette.net website but all they have is the options with the number of them installed.
Old Apr 27, 2003 | 04:37 PM
Black Snowman's Avatar
Black Snowman
Default Re: Create you own build sheet - Custom! (QuickVet)
Priced out what I would have wanted from '74 and it came to $7847.50
I wish I could get it in that kind of shape now for that price ;)
Old Apr 28, 2003 | 02:38 AM
FinnShark's Avatar
FinnShark
Thanks for the link! Great thing to make window sticker, even though it is not lookin like the original one... :cheers:
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Create you own build sheet - Custom! (Black Snowman)
That's cool.....Thanks :cheers:
Old Apr 28, 2003 | 09:44 AM
mapman's Avatar
mapman
Default Re: Create you own build sheet - Custom! (battsup)
... does anybody know of a website that has the prices for the options listed? .....
Option prices are in the Corvette Black Book.
Old Apr 28, 2003 | 09:55 AM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Create you own build sheet - Custom! (mapman)
That is great im gone to modify one for mine with 700r4 and electron blue paint and tpi.thanks for the link :thumbs:
Old Apr 28, 2003 | 10:05 AM
theandies's Avatar
theandies
Default Re: Create you own build sheet - Custom! (patsnitrovette)
:hurray: :hurray:
Cool, all I need is my VIN (no I don't have it memorized yet) and I am going to print one out. Thanks
NHvette's Avatar
NHvette
Yeah - saw that site a while back.
What's really cool is that you can add your own custom options.
My 70 sticker has the (one-only) L75 '75 front end option. :lol: :lolg:
That ultra modern front clip cost $2375 as an option in '70.
http://nhvette.homeunix.com/ftp/in/N...w_sticker2.gif
:seeya
[Modified by NHvette, 10:28 AM 4/28/2003]
[Modified by NHvette, 10:29 AM 4/28/2003]
Old Apr 28, 2003 | 01:07 PM
XLAR8R's Avatar
XLAR8R
I printed one off, thanks. How do I find out what the other
options cost back then ?
Old Apr 28, 2003 | 01:55 PM
Tom73's Avatar
Tom73
Igot excited about a build sheet, but when I went over and took a look it is only the window sticker :cry
tom...
Old Apr 28, 2003 | 01:59 PM
NHvette's Avatar
NHvette
Default Re: Create you own build sheet - Custom! (Tom73)
Anyone have a GOOD picture of a build sheet (tank sheet) ?
I would gladly work up a template that can be used to create your own
custom or reproduction build sheet. I have none - so I would most definitely
follow through on this.
PS - re: cost of options. I have the Richard Prince restoration guide. It lists the cost for base/options over all C3 years in the back section.
:seeya
[Modified by NHvette, 2:01 PM 4/28/2003]
Old Apr 28, 2003 | 02:30 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Default Re: Create you own build sheet - Custom! (NHvette)
NH,
I have a scan of both my Tank Sticker (whats left of it) and also the build sheet that was attached under the carpet. Both are identical. I have started fiddling with the scan to make it pretty but can forward you what I have. Files are large but I can reduce the size down to email it or can chuck it on CD as is.
Mine is for a 70 vert, 350, 4spd.
Just IM me your email and I will get it out to you.
:steering:
To Create you own build sheet - Custom!
Old Apr 28, 2003 | 03:56 PM
Robert N's Avatar
Robert N
tom...
Me too. :cry
Old Apr 28, 2003 | 10:26 PM
JB's Avatar
JB
St. Jude Contributor
Weird--tried to do this & they don't have Monza Red listed under the '69 as an exterior color. They've got Rally Red instead, which is dead wrong. I'm bummed!
JB
Old Apr 28, 2003 | 11:25 PM
aussiejohn's Avatar
aussiejohn
Paul,
Thanks for the link. I printed out a "window sticker" with an "Australian Compliance @ $350" in it. I also ordered a weatherstripping kit from Davies for my 1974 coupe and will let the Forum know how long it takes to get to Australia.
Regards from Down Under
aussiejohn
