Sagging Hood
Old Apr 28, 2003 | 11:17 AM
28buick's Avatar
28buick
Default Sagging Hood
On my 75 the hood seems to have drooped in the area of the fender bump outs. This is to the point where the hood closes fine but the corners of the hood at the windshield are well above the fenders. I have tried aligning the thing but have been unable to eliminate the problem. Is this a common problem with this era vette and is there anything that can be done short of a new hood.
Old Apr 28, 2003 | 01:03 PM
jimvette999's Avatar
jimvette999
Default Re: Sagging Hood (28buick)
Eckler's (and other companies) sell black rubber spacers that are placed in rails to remedy that. Should help in area toward windshield at the same time.
Old Apr 28, 2003 | 01:12 PM
28buick's Avatar
28buick
If you install the rubber spacers in the area thats sagging do you then flex the hood to close it and thats what aligns it.
Old Apr 28, 2003 | 01:34 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Yep, that's the problem. Mine is missing all but one of the rubber hood supports the factory installs. They are usually removed when the car gets repainted. I bought mine from Eckler's. Most restoration catalogs have them.
Old Apr 28, 2003 | 02:05 PM
jimvette999
Dropping the hood to close (within reason..say 10-12" drop) will should work. If not, you close just lower hood and press down each side to latch. Time and heat should help hood conform more to the natural arc you need. Others may have their own way to lower hood but this is how I've always closed mine. Never any problems. Rubber spacers are glued on one side but you can trim the top down if they are too high. I would not just drop hood until I had achieved correct thickness with trial fits.
Old Apr 28, 2003 | 02:24 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Default Re: Sagging Hood (jimvette999)
Jim,
Thanks for the advice. Mine has a little sag on side of the hood near the right fender also.
Off to Ecklers I go.....
:steering:
Old Apr 28, 2003 | 04:03 PM
jimvette999
Default Re: Sagging Hood (stingry)
You're welcome!.... good luck stingry
Jim
[Modified by jimvette999, 4:04 PM 4/28/2003]
Old Apr 28, 2003 | 09:21 PM
arrio76's Avatar
arrio76
Mine is sagging tween the fenders too. Thanks for the tip :D
To Sagging Hood
