fuel pump
Old Apr 29, 2003 | 12:04 AM
SizzleChest's Avatar
SizzleChest
Default fuel pump
what are the symptoms of a fuel pump that is on its way out? my car has been really studdering when i give it gas. it almost feels like it's jumping. is that a faulty fuel pump or something else? thanks!
Old Apr 29, 2003 | 12:09 AM
Black Snowman's Avatar
Black Snowman
Default Re: fuel pump (SizzleChest)
Before you blame the pump check the filter. It's easy to forget about and can make a huge differance. I like to run fuel system cleaner through right after changing the filter to get any accumulated gunk out.
That's something a lot of people don't think of when using fuel system cleaners is that they could be pumping gunk out of the filter and into the engine :eek:
If you notice no change I'd then check for vaccuum leaks (damaged hoses or ones that have fallen off are easy to miss) and THEN start thinking about shelling out money for a pump.
Hope that helps. :cheers:
Old Apr 29, 2003 | 12:13 AM
SizzleChest
Default Re: fuel pump (Black Snowman)
vaccum leaks... uh-oh. that could be it. i found a rat on my engine about a week ago. litte bastards!
To fuel pump
