Are all SBC timing tabs the same?
Old Apr 29, 2003 | 08:02 AM
Neo Fender's Avatar
Neo Fender
Default Are all SBC timing tabs the same?
The timing tab on my '77 Camaro (305 CID) is MIA. Is this a "one size fits all SBCs" item or what?
Old Apr 29, 2003 | 08:09 AM
Pete79L82's Avatar
Pete79L82
Default Re: Are all SBC timing tabs the same? (Neo Fender)
No thay are not all the same. The timing tab must match the balancer diameter and different year balancers had different keyway locations so the tab must be for the correct keyway location also.
Old May 1, 2003 | 12:29 AM
joe73vette's Avatar
joe73vette
Default Re: Are all SBC timing tabs the same? (Pete79L82)
They also mounted in different locations around the damper. Joe
Old May 1, 2003 | 10:31 AM
MasterDave's Avatar
MasterDave
Moderator
Just find TDC on #1 on the compression stroke, spot the mark on your dampner and install a timing tab that aligns with the dampner. Or make your own mark on the dampner to align with one of the aftermarket tabs that sits on the drivers side of the timing cover. :cheers:
To Are all SBC timing tabs the same?
