Wheel Size and Speedo Accuracy
Old Apr 29, 2003 | 08:43 AM
Mystery Machine's Avatar
Mystery Machine
Default Wheel Size and Speedo Accuracy
OK, stupid question time...do the front tires have any bearing on the speedo accuracy if I change wheel/tire size? I am going from 235/60/15 all the way around to a 17" wheel and am trying to figure out what size I need to keep the speedo accurate.
Thanks! :thumbs:
Old Apr 29, 2003 | 08:49 AM
mrvette's Avatar
mrvette
Default Re: Wheel Size and Speedo Accuracy (Mystery Machine)
Hell no, the speedo runs off the driveshaft....from the output shaft of the tranny....you need to compare tire diameters, and if you don't change the rear ratio....you can maybe get away with changing nothing...assuming it's 'right' now.....
GENE
Old Apr 29, 2003 | 09:50 AM
Brettmc's Avatar
Brettmc
Wasn't there a formula posted here that used tire height (or diameter?), rear ratio, and some other stuff to determine what speedo gear was needed for the tranny?
Brett :thumbs:
Old Apr 29, 2003 | 09:55 AM
Schmucker's Avatar
Schmucker
http://www.miata.net/garage/tirecalc.html
To Wheel Size and Speedo Accuracy
