Broken fuel line
Old Apr 29, 2003 | 03:08 PM
stickben's Avatar
stickben
Default Broken fuel line
Hello!
Today I was replacing my fuel pump and I noticed that the metal fuel line was bent up at about a 45 degree angle. I was also replacing the S shaped rubber fuel line to the pump and it wouldnt reach unless the end of the metal fuel line was closer to the frame, so stupid me, I tried to slowly bend the line back down. I immediatly noticed fuel oozing out where the metal fuel line is mounted to the frame :mad . So, Is there any way to patch the line? I was thinking of just cutting it off at the mount and running a rubber line to the S hose.
Any suggestions?
Old Apr 29, 2003 | 04:37 PM
jimvette999's Avatar
jimvette999
Default Re: Broken fuel line (stickben)
IMO, I would minimize the use/length of rubber fuel line if it were mine. Only 5-7 psi but if that hose gets rubbed, cut, burnt or old and cracked ...bad news. Pop for a new line from Eckler's and put an end to it.
Jim
Old Apr 29, 2003 | 04:40 PM
Brettmc's Avatar
Brettmc
If you do decide to go with a rubber line, inspect it every time you change your oil. If it looks suspect, replace it.
Brett :thumbs:
Old Apr 29, 2003 | 04:42 PM
Fevre's Avatar
Fevre
A braided line would help minimize the chance of rub through.
To Broken fuel line
