engine gurus: Stuttering after WOT
Old Apr 29, 2003 | 08:45 PM
java0881's Avatar
java0881
Default engine gurus: Stuttering after WOT
the car runs smooth,but when the engine is warm and i go trough the gears at full throttle(of course only 1st and 2nd :D )right away it starts to stutter and wants to shut down,no idle.if i turn the engine off for a couple of minutes,everything is fine.sofar i replaced the plugs,wires,points,dist.cap and the coil.does this indicate a problem with fuel delivery,meaning its starving for fuel after WOT?
thanks for the help
Old Apr 29, 2003 | 09:15 PM
Stefan69's Avatar
Stefan69
Default Re: engine gurus: Stuttering after WOT (java0881)
Can you go WOT right away again, even if she's stuttering adn shaking? If so it can't be fuel starvation. In that case my guess would be too rich of a mix. check the float levels.
Good luck!
Stefan
Old Apr 30, 2003 | 12:25 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Re: engine gurus: Stuttering after WOT (Stefan69)
:iagree:
Also check for dirt in the needle/seat.
Old Apr 30, 2003 | 02:28 AM
Turbo-Jet's Avatar
Turbo-Jet
if it is fuel related, what rpm does it stutter?
low rpm=accel pump, vacuum secondaries
high rpm=float level, restriction in lines or filter
Old Apr 30, 2003 | 06:12 PM
java0881's Avatar
java0881
Default Re: engine gurus: Stuttering after WOT (Turbo-Jet)
i can accelerate 1 time through the gears with no problems,but when i slow down right after,thats when it starts to sputter and wants to shut down,no idle.i can still rev the engine but if i engage the clutch it just dies.
Old Apr 30, 2003 | 07:01 PM
WashingtonRacer's Avatar
WashingtonRacer
what kind of carb do you have? I had the same issue with my truck, but it slowly, "actually quickly" got worse and worse, pretty soon it would occure after jut cruzing at around 60, then 40, then 10, then it just died. the metering jets were just worn out.
can you hold a high RPM rev?
Old Apr 30, 2003 | 07:45 PM
vette_c5c6's Avatar
vette_c5c6
You did not indicate the type of carb on your vette. If you a running a Q-jet with that little silly fuel filter I woud suggest you remove it and install an external inline filter. I had a hell of of a time years ago when I owned a 72- 454. By replacing the filter, that solved my problems. Good luck
Old Apr 30, 2003 | 10:15 PM
java0881's Avatar
java0881
Default Re: engine gurus: Stuttering after WOT (vette_c5c6)
here are some pics of the carb.its a Bill Mitchell-Holley
i hope this helps
Old May 1, 2003 | 08:15 AM
Cookwithvette's Avatar
Cookwithvette
When I changed the needle-seat valve on my Demon I had the float level a little high and had the EXACT trouble you describe. After hard accelleration it would want to die if I didn't give it throttle. Lowered the float, trouble disappeared. Good luck! :cheers:
Old May 1, 2003 | 08:25 PM
java0881's Avatar
java0881
Default Re: engine gurus: Stuttering after WOT (Cookwithvette)
so where can i adjust the float level?
thanks
Old May 1, 2003 | 10:22 PM
Cookwithvette
See on the tops of the fuel bowls the screw on top of the nut? Loosen that screw a little, just enough to turn the nut, and ... turn the nut. Clockwise to lower, Counter clockwise to raise. They can be adjusted independantly and it can also be done with the engine running. The benefit to this is you'll be able to watch the changes in the sight glasses (seen on your first photo near the inlets). Bear in mind that adjusting downward won't have an immediate effect. It will take a few moments for the fuel level to drop.
You may wish to mark your current fuel level so if this doesn't fix your problem, or creates another (carbs are great for that), you have a setting to return to.
Good luck! :cheers:
Old May 1, 2003 | 11:01 PM
java0881's Avatar
java0881
thanks a lot cookwithvette.i'll try that this weekend :thumbs:
To engine gurus: Stuttering after WOT
