Tach problem....
Old Apr 30, 2003 | 12:18 AM
ice pac's Avatar
ice pac
Default Tach problem....
Since I've had the car I've noticed my tach to rest at 3k rpm's. When I start the motor it jumpes to 4500. Give it a little gas and it redlines. The tach is obviously working, it's just set way to high. What can I do to fix this?
Old Apr 30, 2003 | 06:32 AM
Fleetwood's Avatar
Fleetwood
Default Re: Tach problem.... (ice pac)
Sounds like a fault with the printed circuit board on the back of the tack,you may be up for a new one.Check for burn marks on the board,you may get
away with cleaning it.
Old Apr 30, 2003 | 11:14 AM
75Rag's Avatar
75Rag
Default Re: Tach problem.... (Fleetwood)
:iagree: Mine did that for a while then the needle fell off ........ new board will fix it. The board replacement is easy ... rippin the tach out of the dash is a true PITA :mad
[Modified by 75Rag, 4:16 PM 4/30/2003]
Old Apr 30, 2003 | 12:02 PM
aharte's Avatar
aharte
I think that if you pull the needle off, and put it back on such that it reads 0 when the car is off, everything will be ok. The internal electronics doesn't have any way of knowing which way the needle is stuck on.
Old Apr 30, 2003 | 07:34 PM
ice pac's Avatar
ice pac
Default Re: Tach problem.... (aharte)
I think I'm gonna try just to set the needle at zero as mentioned. How do I get the needle off? I was looked at it but I couldn't tell how it's fastened.
To Tach problem....
