harmonic balancer puller/installer sets
Old Apr 30, 2003 | 02:09 AM
sharkthehunter77's Avatar
sharkthehunter77
Default harmonic balancer puller/installer sets
Offcourse i am in the middle of pulling my balancer and the one at the auto hobby shop has seen much better days. What types are a good one to get and what size bolts are used to hold the balancer in place while you torque against it? I guess i neeed to know the size of the balancer bolts! And if anyone has any tricks on this feel free to list them!
Old Apr 30, 2003 | 06:51 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: harmonic balancer puller/installer sets (sharkthehunter77)
I bought one from Auto Zone. I came with 3-4 different size bolts to cover multiple makes. after you remove the crank bolt, take the washer off and put the bolt back into the crank. It doesn't need to be real tight though. Then use the balancer remover. This will prevent damaging the crank bolt threads with the pointed part of the remover. Don't ask how I know.
I bought a separate "installer" from J.C. Whitney for $20. :chevy
Old Apr 30, 2003 | 07:15 AM
virtue4u's Avatar
virtue4u
Default Re: harmonic balancer puller/installer sets (1970 Stingray)
What does the installer do? Can you provide a photo? I must change the front seal soon.
Old Apr 30, 2003 | 08:40 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Default Re: harmonic balancer puller/installer sets (virtue4u)
Here's a pic from Jeg's....this one is $44, and I could be wrong on the Whitney price. Sure beats hammering it on, which is a no-no.
The installer main bolt srews into the crank and the silver portion is turned slowly, pushing the balancer onto the crank snout.
[Modified by 1970 Stingray, 8:43 AM 4/30/2003]
Old Apr 30, 2003 | 08:47 AM
Brettmc's Avatar
Brettmc
Do you lube the crank snout or pulley bushing with oil before installation? Or would that make it too easy? :D
Brett :thumbs:
Old Apr 30, 2003 | 08:56 AM
Fevre's Avatar
Fevre
Default Re: harmonic balancer puller/installer sets (Brettmc)
Brett :thumbs:
That is what I do plus start it with a longer bolt (ARP lube on threads and snout) then switch to the regular bolt. Slides on pretty easy and only cost about $1 for the longer bolt to get it going on.
Old Apr 30, 2003 | 02:03 PM
zymurgist's Avatar
zymurgist
I got a really nice one from Summit Racing. (SUM-G1025-01) It's about 100 bucks but it looks like it will last forever in any hobbyist's garage.
To harmonic balancer puller/installer sets
