Replacing Rear-end gears...help!
Old Apr 30, 2003 | 01:45 PM
OBL1V1ON's Avatar
OBL1V1ON
Default Replacing Rear-end gears...help!
Ok i orderd a set of 4.11s for my 79 and i would like to install them, but there is a small problem...I have never installed gears before.
Should i do this myself, or should i take it to a shop and have it done. If i should do it myself is there anyone out there that could perhaps give me some instructions on this project.
Any help would be appreciated
Old Apr 30, 2003 | 02:02 PM
IRON WILL's Avatar
IRON WILL
Default Re: Replacing Rear-end gears...help! (OBL1V1ON)
There are a few special tools required to do this yourself. I am not sure but you may need a different carrier for those gears. I would check with the people you are buying the gears from they should be able to tell you everything you need. i just recently put gears in my 1980. I used 3.73 and was able to use the stock carrier. I would try and find someone to do it or to help you do it. I wish I had... I ended up removing the rear a second time and having a dealer re-setup the rear for me. Luckly I made a few guess changes before I gave it to him and he didn't have to do anything to it. I lucked out if you ask me. Another thing to do is you can check with a local Vocational school (BOCES, or other schools that teach auto mech.) They will sometimes make a lesson out of the project and all it costs you is parts. There are several ways to go. But if you do not have some of the special tools needed you will only do more harm than good. Hope this helps some. I just got through my little gear headache. Wish I had some one else do it right the first time.
Old Apr 30, 2003 | 02:33 PM
redvetracr's Avatar
redvetracr
As posted above you need a 4-series posi (or a spacer-NOT recomended) and some special tools. This is the one of the few jobs I would NOT tackle.
...redvetracr
Old Apr 30, 2003 | 02:57 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Re: Replacing Rear-end gears...help! (redvetracr)
Yep you ned that 4 series carrier. They run about $400. Doing the rear can be somewhat difficult. Your main problem will probably with the clutch pack if you've never done it before. You may want to take it to a local gear shop and have them do that for you. The rest of the project is pretty simple.
Old Apr 30, 2003 | 02:59 PM
Brettmc's Avatar
Brettmc
if u have a 3-series gear now, the 4.11s prolly won't fit, unless they are made to fit on a 3-series carrier. might not be a bad idea to upgrade to an Eaton 4-series carrier. I set up a 10-bolt once for a 69 Camaro I once owned, but it whined a little on deceleration. I used the grease method to determine the gears' relationship. It can be done without special tools but you run a bigger chance of the gear relationship not being right if you don't read the grease well enough. If I did this again, I would definitely buy the micrometers to do the job right. There's a ton of printed help on this.
Brett :thumbs:
Old Apr 30, 2003 | 04:50 PM
Gordonm's Avatar
Gordonm
Default Re: Replacing Rear-end gears...help! (gtr1999)
Here is a 3 and 4 series carrier. The one on the left is the 4 series
Old Apr 30, 2003 | 04:55 PM
Fevre's Avatar
Fevre
What are your plans for the car? You might want to return the 4.11 and get a 3.90 if your heart is set on a low gear. I have a 3.70 and wish I had a 3.55.
Old Apr 30, 2003 | 09:39 PM
LemansBlue68's Avatar
LemansBlue68
I'm not afraid of doing any kind of rebuild work normally, but I sent my rear end out to be done for the following reasons:
1) The special fixtures required to set up the gears would be much too expensive to buy considering how little I would use them and I don't know anyone that HAS them let alone would let me borrow or rent them. The cost of the tools would cost as much as the rebuild.
2) Getting the pinion depth and shims set properly is critical to the job to ensure that the gears operate quietly and wear correctly.
3) It would be way too much of a PIA to take the rear end out back out of the car to fix it if I screwed something up.
I'd say ante up the bucks to let someone who specializes in this kind of work get it done right for you the first time.
Good luck whatever you decide!
Eric H
Old Apr 30, 2003 | 09:50 PM
Jvette73's Avatar
Jvette73
I will verify that 3.90's will fit the 3 series carrier. Thats as low as you can go on the 3 series carrier. I got 3.90 on my 3 series that originally had 3.08
[Modified by Jvette73, 8:50 PM 4/30/2003]
Old May 1, 2003 | 12:39 AM
OBL1V1ON's Avatar
OBL1V1ON
Default Re: Replacing Rear-end gears...help! (Jvette73)
Well i know i want to stick with the 4.11s b/c i got a great deal on them. And this car is just a cruiser/street racer so gas isnt an issue either.
So now all i have to do is get a 4 series carrier and take it to a shop, right?.......sounds simple enough.
Guess ill start looking for a 4series carrier.....uhg part hunting never ends...
Old May 1, 2003 | 12:42 AM
ken markusa's Avatar
ken markusa
Your best bet is to take out the pumpkin yourself and take it to a shop the cost should be pretty cheap because they can do it on a bench.
Ken :cheers:
Old May 1, 2003 | 01:36 AM
Rockn-Roll's Avatar
Rockn-Roll
I was initially doing my own rear end. Everything was going great until I go to the point where I needed to install the carrier assembly. The big problem is that the assembly NEEDS to be installed as a tolerance fit which means using a press to wedge it in there, and to use the exact amount of shims to line it up and get the proper compression after it's in there. I tried the old hammer and wound up cracking the pinion and just turning my rear end into a piece of junk.
I recommend taking the rear end to a shop. You might want to assemble the clutches and pumpkin by yourself just to make sure it's done right, but when it comes to lining everything up and getting the proper compression on the bearings then I suggest a shop that has done these before. In fact, when I replace my stock rear-end I will be buying a complete rear-end new from a factory.
Old May 12, 2003 | 06:57 PM
OBL1V1ON's Avatar
OBL1V1ON
Default Re: Replacing Rear-end gears...help! (Rockn-Roll)
Guess what guys.............I found a place that makes 4.11s for a 3 series carrier!
Theyll be installed in a week or so. Ill let you you guys know how it does.
Old May 12, 2003 | 07:37 PM
Alwyn678's Avatar
Alwyn678
Default Re: Replacing Rear-end gears...help! (Van Steel)
:withstupid: It is easy to take out but the set up has to be perfect
Old May 12, 2003 | 09:34 PM
norvalwilhelm's Avatar
norvalwilhelm
Guys it is no black majic setting up gears. With a simple press, a dial indicator, marking compound, factory shim packages, a torque wrench , actually 2 and a pinion bearing puller it is not hard at all.
I have talked various member through this process before but you must have the above tools or at least access to them.
I have a pinion checking micrometer but seldom use it. I go with the grease method.
I would not pay hundreds of dollars for something I can do myself.
Old May 12, 2003 | 10:58 PM
ram82fire's Avatar
ram82fire
Default Re: Replacing Rear-end gears...help! (norvalwilhelm)
:iagree: Norval is right ,checking the pattern always works out . I have done numerous rears , and some times after doing the set up using a pinion depth tool you find the pattern is simply in the wrong place . It is pretty easy to make a spreader for the housings , and is quite handy during assembly .
Geo
Old May 13, 2003 | 11:29 AM
Alwyn678's Avatar
Alwyn678
I only payed 25 bucks to have the machine shop to set it up
Old May 13, 2003 | 09:55 PM
norvalwilhelm
Default Re: Replacing Rear-end gears...help! (Alwyn678)
You got a real deal Alwyn678. That doesn't even cover 1/2 hour of labor. I spend a couple of evening setting up a set but when I am done I know the pattern is right and they will not howl. I believe it is hundreds to set up a rear end but having never paid for it I wouldn't know.
Old May 13, 2003 | 10:05 PM
BKbroiler's Avatar
BKbroiler
I have a slightly off - topic question for you guys. Can the pumpkin be removed without dropping the exhaust pipes? Would removing the spare tire carrier provide enough room to slide the pumpkin back and then down? Thanks for any info.
To Replacing Rear-end gears...help!
