Tips and tricks...
Old May 1, 2003 | 09:54 AM
VettePekka's Avatar
VettePekka
Default Tips and tricks...
Hi all,
I am about to replace the whole carpet of my -72. I am sure many of you have gone through that process, and I would value your tips, advice and notes of caution. is there anything special that I really, really want to consider before and while doing it?
What to do in which order, and what not to do...?
Can you suggest any good source (vendor) for replacement carpets. Corvette Trader has a lot of ads - is there anything else besides the price that I want to be concerned about (quality differences...)?
Thanks in advance!
Pete
Old May 1, 2003 | 10:31 AM
jimvette999's Avatar
jimvette999
Default Re: Tips and tricks... (VettePekka)
I prefer molded carpet and a non- cut pile. Less fuzz and better wear. Corvette America sells it as does Eckler's. You may want to put down a sound/heat barrier while you are at it. Check floor pans for rust and remedy that while you are there.
Jim
Old May 1, 2003 | 10:33 AM
jimvette999
Avoid cheap carpet at all costs! i.e. J.C. Whitney
Here is Corvette America carpet installed.
[Modified by jimvette999, 10:34 AM 5/1/2003]
Old May 1, 2003 | 10:34 AM
Alwyn678's Avatar
Alwyn678
Default Re: Tips and tricks... (jimvette999)
Check with http://www.tld.com I went to an upholster and had them cut mine
[Modified by Alwyn678, 10:35 AM 5/1/2003]
Old May 1, 2003 | 11:05 AM
VettePekka's Avatar
VettePekka
Thanks a lot for the info so far. Every bit of advice is greatly appreciated!
Any other suggestions?
As you can see from the # of post, I am new to this site - I have been lurking for quite awhile though. I used to have a -80, but sold it a few years ago. But once you get the Corevette fever it sticks into your bones/blood. Just recently I ended up with this -72 I now have.
Pete
Old May 1, 2003 | 04:41 PM
gmcclurg's Avatar
gmcclurg
Most of the vendors uss ACC Carpet. If you do a search you will find that most people buy from, The Last Detail, Zip, Echlers, or Willcox. Shop around and find the best price. I just finished this on my car, email if you have any questions.
Old May 1, 2003 | 04:44 PM
75Rag's Avatar
75Rag
1) Take your time
2) Measure twice, cut once
3) Buy the best you can afford
4) Consume minimal beer during installation, celebrate your accompishments later
5) Add sound/heat insulation
6) Use soldering iron to "burn and seal" holes instead of cutting
I just did this last year using Corvette America materials. It took longer than I expected and it all fit perfectly except the right rear section. You will have some minor trimming to do which is why #2 is so important I ALMOST trimmed too much and was very close to ruining the entire section.
Good luck .... show us the pics when you're done!!
Michael
Old May 1, 2003 | 10:27 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: Tips and tricks... (gmcclurg)
:iagree: i bought my seats from Wilcox because i was so impressed with there friendliness and helpfulness...
when i asked about carpet they were happy to send me samples of the type and colors that i am considering...
in fact the owner himself and i shared several emails back and forth concerning my questions etc...
i like that kind of customer relations... :yesnod:
Old May 2, 2003 | 11:39 AM
adamdinat's Avatar
adamdinat
Default Re: Tips and tricks... (Alwyn678)
How did that work out? I have a replacement carpet in mine and it looks like one. I was considering going to an upolstery shop thinking they would do a better job fitting the carpet. Can you tell the difference.
Old May 2, 2003 | 01:06 PM
UKPaul's Avatar
UKPaul
Default Re: Tips and tricks... (SIGNGUY)
Signguy :seeya
It's me again! Could you send me the owners email address? As you know, I'm restoring my seats, & the carpet on the backs is fit for the bin. So I'm after somewhere that will sell me just those 2 pieces :)
And you're not wrong about good customer relations being important :mad
:cheers:
edit: Carpet installation - I'm changing my front carpets at the moment & was told by a Vette restorer to do it on a warm day & run the engine for a while with the heater on full blast to get the interior nice & warm prior to fitting the carpet. Apparently this will help prevent any problems with the carpet moving at a later date.
[Modified by UKPaul, 6:20 PM 5/2/2003]
To Tips and tricks...
