Mud Flaps for my 69
Old May 1, 2003 | 09:10 PM
69shark's Avatar
69shark
From: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
Default Mud Flaps for my 69
What are you guys with 68/69's using for mud flaps? I need soemthing to keep the gravel and water from running up the side of mine ut I don't want to put anything permanent on it. If you have pictures that would be cool.
Thanks :chevy
Old May 1, 2003 | 09:13 PM
bbeck's Avatar
bbeck
Default Re: Mud Flaps for my 69 (69shark)
I don't run anything, and you can definitely tell, after going through any water or dust, it's all over the car. :(
Old May 1, 2003 | 09:14 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Nothing now, the mud makes it look better...
But if / when it gets painted I will need flaps too I guess...
Old May 1, 2003 | 09:16 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
I would run motorcycle tires, they'll be inside the wheel wells, ergo: no mud! :lolg:
Old May 1, 2003 | 09:29 PM
69shark's Avatar
69shark
Cruise-In I Veteran
Default Re: Mud Flaps for my 69 (SEE3ER)
Well, I'm going to need something to keep the rubber off after the 383 goes in :p: wanna race :p: :auto: :steering:
Old May 1, 2003 | 09:32 PM
sb69coupe's Avatar
sb69coupe
Two Words:
BACK OFF!!!!
Yep, I got me a set o' them thar Yosemite Sam flaps. They look real good. I got 'em after somebody stole my other set of flaps. the ones with the reclining Nekkid Chick on 'em.
:jester
Old May 1, 2003 | 09:33 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Go ahead, hit below the belt! :banghead: My last 383 was in my RoadRunner! :D Can't wait to see that Bad Boy! :reddevil
Old May 1, 2003 | 11:15 PM
Corey_68's Avatar
Corey_68
I don't know aout you guys, but I rather touch up the fenders every couple of years instead of running mud flaps. I think it really takes away from the lines of the car. But I can understand your concern especially with my chrome sidepipes. :(
Old May 2, 2003 | 03:40 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Mud Flaps for my 69 (Corey 68)
Just make sure they are big enough to get the MudFlap girlie's on them :lol:
Old May 2, 2003 | 08:14 AM
snb73's Avatar
snb73
Default Re: Mud Flaps for my 69 (Desertdawg)
I think this might be more of what you are after.
I was dropping off my steering gear box at Tony's Corvette Shop, in Gaithersburg Maryland, for a rebuild. I noticed a nice 63. Upon closer inspection, I saw the owner installed mud flaps. Here's how he did it:
A peice of clear 1/8 inch lexan was cut into a traditional mud flap shape. This can be obtained from any home store. The unique thing, was the mounting method. The flap was held inplace by paper clips. Not the silver ones that only hold 3 or 4 papers, I'm talking about the black metal ones with the silver arms. These arms are used for leverage to open the clip and be folded out of the way or removed after use. You can buy different sizes 1/4 inch up to 2 inches, at any office supply store. Two clips were used to hold the flap to the edge of the fender well.
This way you can remove or install them any time you want quickly. It offers you clean and stealthy protection, with out permanent mounting holes. I'm sure you can make all four for about $30.
Hope this helps, Steve.
Old May 2, 2003 | 08:38 AM
theandies's Avatar
theandies
Default Re: Mud Flaps for my 69 (snb73)
One of the vendors (can't remember which one though) sells clear, removable mud flaps for C3's. Look through the catalogs, you'll find them.
Old May 2, 2003 | 10:05 AM
Burgundy 69's Avatar
Burgundy 69
I picked up a set of clear acrylic "chip clips" from MAD (I think). They came with a set of metal clips that are supposed to mount to the inner fender trim. After playing with them for half an hour, I went into the house and found four LARGE paper clips (no, not those, the black metal type that snap together and hold a large block of paper) which worked just right. I can get the plastic guards off in a snap and have yet to loose one.
Although I'm not 100% safe, I feel a lot better about driving these NH roads where large stones are a way of life.
Old May 2, 2003 | 10:49 AM
BB wowbagger's Avatar
BB wowbagger
Default Re: Mud Flaps for my 69 (Burgandy 69)
I need to design some flaps to my vette.I hate to hear the sound of gravel bounce of the chromed sidemounts..
That Lexan idea was really smart.. :thumbs: :cheers: :cheers:
To Mud Flaps for my 69
