Rear spring bolts
Old May 2, 2003 | 04:58 PM
Brettmc's Avatar
Brettmc
Default Rear spring bolts
Yesterday I purchased 2 grade 8 8" rear spring bolts with locknuts from a local industrial fastener biz for $5.50. Sure beats the vette supplier's price of ~ $20. Anyone who wants to lower their rear (their vette's rear, that is), check locally first.
Brett :thumbs:
Old May 2, 2003 | 05:01 PM
Corey_68's Avatar
Corey_68
Default Re: Rear spring bolts (Brettmc)
I ordered the set and installed them last weekend. It dropped the car a whole 1/2 inch. :rolleyes: I don't know if this is due to my rear fiberglass spring or not. I did as you did and found some longer bolts locally for about $6.
:cheers:
Old May 2, 2003 | 05:03 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: Rear spring bolts (Corey 68)
Just make sure you get a good qualitybolt.You dont want to take a chance on these bolts.. :smash: :smash: :cheers:
Old May 2, 2003 | 06:37 PM
JJ Deuce's Avatar
JJ Deuce
Corey-
how long were the bolts you installed? I have the same problem with the fiberglass spring on my '69. The rear of my car sits about 2 1/2" too high (my sig pic was taken before the new spring). The longer bolts from the 'vette parts suppliers only appear to be 8" long. I don't want to switch them out if it's only going to drop a 1/2".
Old May 2, 2003 | 06:42 PM
killain's Avatar
killain
Oldtimer
Don't you need bolts with cotter pin holes in them? You know for safety !
Old May 2, 2003 | 06:59 PM
Corey_68's Avatar
Corey_68
Default Re: Rear spring bolts (Jeff 6T9)
Jeff, I'm going to the shop in a little bit and I'll take some measurements for you of the bolts and with the new bolts installed. I picked up the longer bolts today and I'll take pics of the bolts after for you. I do believe the Vette Brakes bolts are 8" long.
:cheers:
Old May 2, 2003 | 08:33 PM
Corey_68's Avatar
Corey_68
Jeff,
Just came back from the shop.
Here is how the car sits with the Vette Brakes rear lowering bots and fiberglass rear spring.
It sits at 30 3/4.
Here are the bolts.
The galvanized bolt, the gold Vette Brakes bolt and black stock bolt. I'm going to have to shave the new bolt to fit through the hole.
Old May 2, 2003 | 09:16 PM
Edzred72's Avatar
Edzred72
Corey: Is that galvanized carriage bolt in the pic the one your going to use on the rear spring?? DO NOT use it unless it's a grade 8. (I've never seen a grade 8 carriage bolt)
Eddie
Here are the bolts.
[/QUOTE]
Old May 2, 2003 | 09:26 PM
Corey_68's Avatar
Corey_68
Default Re: Rear spring bolts (Silvr77)
Eddie
Eddie, not this is not the bolt I will be going with, I realized after I left it wasn't Grade 8. I will probably use an "all thread" and weld a nut on top so in reality I can lower the car as much as I want. I agree, use nothing less than Grade 8 for strength. :thumbs:
[Modified by Corey 68, 10:24 PM 5/2/2003]
Old May 2, 2003 | 11:30 PM
snb73's Avatar
snb73
Corey,
I had the same problem after I added a fiberglass spring. I used the lowering bolt from Vette Brakes, but it wasn't enough. I went to the local fastener shop and purchased grade 8 all-thread and six grade 8 nuts. I spot welded one nut to the top and used the other two as locking nuts for the bottom. Less than $10 for all. I needed 10 1/2 inches for mine to sit right. Works just fine.
If you go to the Vette Brakes web site, or cataloge, look for the C4 lowering bolts. They are the perfect lenth for a C3 with a fiberglass spring. The part number is 32309 @ $39.95 I am sure locally purchased bolts would be cheaper.
Good Luck, Steve.
Old May 3, 2003 | 12:14 AM
Edzred72's Avatar
Edzred72
I knew you knew that......just makin sure and watchin out fer ya! ;) ;) ;)
Eddie
Old May 3, 2003 | 12:16 AM
Corey_68's Avatar
Corey_68
Eddie
I appreciate the heads up man. :thumbs:
Old May 6, 2003 | 09:54 AM
JJ Deuce's Avatar
JJ Deuce
Corey -
thanks for the info. For some reason I can't see the pics, though.
Let me know how much length you end up needing to get the car where it needs to be. Also, didn't you have some issues with the coils up front, too? I need to replace mine, and I don't want to have the nose high once I get the rear down.
Old May 6, 2003 | 10:04 AM
Corey_68's Avatar
Corey_68
Jeff 6T9
Well, I put the VB bolts back in and going to wait and see how she sits with the battery, convertible top, bumpers and interior. I think with all of that it will drop another 3/4-1in. Same goes for the front, I have yet to add :hood, carb, PB,MC, bumpers, oil, water in the rad. If it doesn't come down any more I will cut 1/4 of a coil off the #550 springs.
I keep you posted :thumbs:
Old May 6, 2003 | 10:44 AM
norvalwilhelm's Avatar
norvalwilhelm
What size did you buy. I have used the 1/2 inch before grade 10 or 12 and it broke driving down the highway.
I went back to my old mild steel bolts for a while then switched once again to 9/16 x 8 inch grade 10 bolt with locking nuts.
I feel the lock nuts will not loosen but still visually check them occasionally.
Old May 6, 2003 | 11:25 AM
Scooter70's Avatar
Scooter70
Default Re: Rear spring bolts (norvalwilhelm)
Guys with 10" bolts and a composite spring:
Can you all check and see how close the end of your spring is to your tire and let me know?
Mine right now is 3/8" from the sidewall and rubs the tire on hard corners. My rear tires are 255 wide but I'm not sure of the backspace on these wheels. Right now my options for fixing this issue is either to go back to the 8" bolt and deal with the higher ride height or find new wheels with different backspace/offset. (My spring has a slight arch, even without a spare tire or tub weighing the back down.)
Old May 6, 2003 | 11:35 AM
Edzred72's Avatar
Edzred72
For a bulletproof lock....drill a small hole through the bolt large enough to accept a cotter pin. Run a die over the threads to remove the burrs, and get a castle nut. Your nut is now locked in. Just my .02... :D :D
Eddie
Old May 6, 2003 | 03:07 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Is there an approximate ratio between how far you move the nut down the bolt and how much the car lowers? Obviously not one to one, or you guys with 10 inchers would be on the ground!
-Chris
[Modified by RUXperienced, 4:02 PM 5/6/2003]
To Rear spring bolts
