vacuum problem
Old May 4, 2003 | 08:19 AM
hauk's Avatar
hauk
Default vacuum problem
My 73 does not make a lot of vacuum,Is there an electric vacuum pump available and if so where can I buy it? :confused:
[Modified by hauk, 9:06 AM 5/4/2003]
Old May 4, 2003 | 08:41 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Default Re: vacuum problem (hauk)
Something like this? http://www.jegs.com/cgi-bin/ncommerc...61&prmenbr=361
Old May 4, 2003 | 04:23 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Are you running a big cam? If not you should have plenty of vacuum as long as it's properly tuned. Are you having trouble operating vacuum accessories?
Old May 4, 2003 | 07:53 PM
bigvette1's Avatar
bigvette1
Default Re: vacuum problem (Vetterodder)
"Are you running a big cam? If not you should have plenty of vacuum as long as it's properly tuned. Are you having trouble operating vacuum accessories?
Unless it really radical there should be at least 14" or so of vacuum at the manifold. Timing, idle adjust etc check them out and measure the vacuum. If you run a big cam get a vacuum cannister for the accessories. A pump really is not needed.
Old May 4, 2003 | 08:17 PM
timbo79's Avatar
timbo79
:iagree:
A pump is not neccessary.. Crane makes a nice vacume cannister for extra storage if you are running a radical cam. I would suggest checking all your hoses, seals and connections.
To vacuum problem
