rear-end fluid
Old May 5, 2003 | 11:07 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default rear-end fluid
I'm going to have the fluid changed in my differential. What type of fluid is best?
Old May 5, 2003 | 11:29 PM
goinbroke's Avatar
goinbroke
Default Re: rear-end fluid (74 vert)
I'm sure there are other opinions, but I used GM axle lubricant #1052271.
Don't forget to add a bottle (4 oz.) of GM limited slip additive # 1052358.
Old May 6, 2003 | 12:05 AM
Rockn-Roll's Avatar
Rockn-Roll
You will need 4 pints (2 quarts). I used an 80W-90 gear lube. I poured out a little from each bottle and squirted half of the 1052358 additive into each one...then shook them up. I recommend this cause the additive is so thick it may take several miles before the ring gear will mix it up in the differential. The specs do call for GM part# 1052271, but I have not seen it listed on any containers in the stores. The standard differential calls for a 80W-90 gear lube, which is why I use that for my rear end and for my manual transmission.
Old May 6, 2003 | 12:55 AM
JB's Avatar
JB
St. Jude Contributor
Default Re: rear-end fluid (Rockn-Roll)
I use Mobil 1.
JB
Old May 6, 2003 | 01:23 AM
RJR99SS's Avatar
RJR99SS
most performance minded people like to use mobil 1 synthetic or redline. If you use mobil 1 you have to use a posi additive if you have posi, but if you use redline you dont have to add an additive as its already in the oil. Of course, its rather hard finding redline.
But i've used mobil 1 synthetic gear lube in several cars of mine, and i can say it made quite a difference. The rear end just felt a whole lot smoother.
Old May 6, 2003 | 08:54 PM
nastee383's Avatar
nastee383
Don't know if it's best but I use Royal Purple 75W90.
To rear-end fluid
