backfire on deceleration
Old May 6, 2003 | 04:09 PM
79corvette's Avatar
79corvette
Default backfire on deceleration
I just installed votec heads, a perfomer vortec manifold, headers, and a dual exhaust with targa style mufflers. Now on decleration the car backfires, only once the car has been warmed up though. Also if I rev it and it comes back down it backfires too(only when the engine is warm). I am using the stock Q-jet. I heard recently that this can be caused by the carb being to lean, if so, how can I adjust this? Thanks for the help as always.
Old May 6, 2003 | 04:44 PM
sammyb's Avatar
sammyb
Default Re: backfire on deceleration (79corvette)
It can also be an indication of an exhaust leak, so make sure that all of your connections are tight and all the gaskets are appropriately sealed.
You should check your spark plugs and see what they look like. If they are black and fouled with fuel, then you're too rich. If they are white or the metal is somewhat destroyed, you're looking at too lean.
Most carbs have a mixture screw. While I don't work on Q-jets, you can search online for the schematics, and it will show which screws set the mixture vs. idle etc...
Old May 6, 2003 | 04:49 PM
Larry B.'s Avatar
Larry B.
Default Re: backfire on deceleration (sammyb)
when you say "backfire" do you mean through the cab or just a pop in the exhaust. They are two complete different things.
Old May 6, 2003 | 04:53 PM
flood's Avatar
flood
Default Re: backfire on deceleration (bluevetteman)
yeah is it backlash or backfire?
does it pop and explode ? thats backfire.
If it just sputters when you let off thats backlash.
Old May 6, 2003 | 04:57 PM
mvftw's Avatar
mvftw
Default Re: backfire on deceleration (flood)
A backfire through your carb...check timing and valve adjustments.
Old May 6, 2003 | 05:12 PM
79corvette's Avatar
79corvette
flood
It sputters little bit, then it will pop maybe twice. It is coming from the exhaust.
I did notice that the spark plugs were a little white. I just changed them last night.
Old May 6, 2003 | 05:56 PM
Langadorf's Avatar
Langadorf
Well this could be normal. When you suddenly decelerate from WOT, for a second your carb will still run really rich. This means some of the gas won't get burnt in the combustion chamber and will pass into the exhaust and finish burning there. If you don't have a restrictive exhaust, it'll make a popping sound when it does this. It happens to me sometimes w/ my true duals also.
However, if this happens everytime you let off the throttle (not WOT), then something else might be going on. Check your timing and carb settings.
[Modified by Langadorf, 4:56 PM 5/6/2003]
Old May 6, 2003 | 06:20 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
What did you do to the carb after you put on a better intake, better heads, better exhaust ?
I hope you are giving that motor some more fuel now.....
Old May 6, 2003 | 07:29 PM
79corvette's Avatar
79corvette
Default Re: backfire on deceleration (BSeery)
It makes the popping every time I let off the throttle.
I haven't touched changed how much fuel flow the engine is recieving since the upgrades. How can I do this? Do I need to get a better fuel pump, or just change the carb settings(I think the mixture screw is coverd on the stock Q-jet, how can i change that)?
[Modified by 79corvette, 7:32 PM 5/6/2003]
Old May 6, 2003 | 07:39 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
What carburetor are you using ?
You would have to change the internal mixture of both the primary and secondary meetering systems for any carb out there. If you don't know carbs, this would be a really good time to get a book and learn, or make some friends with a local person that knows.
Setting a carburetor via instructions over the internet is like trying to instruct someone to paint a painting over a phone.
Old May 6, 2003 | 07:50 PM
LiveandLetDrive's Avatar
LiveandLetDrive
I had popping like this and never did much to fix it, but recently I discovered my distributor mechanical advance was corroded stuck. I was getting about 12 degrees initial + vacuum only!! Once this was fixed, and I now get 36 total advance, the popping is completely gone. Might want to give the timing a check.
-Chris
Old May 6, 2003 | 09:00 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: backfire on deceleration (Langadorf)
The idle mixure is not right and the carb is drawing fuel out of the transfer slots causing the backfire. If you see stock cars in the corners shooting flames on deceleration it is fuel being sucked out of the carb. The transfer slots need to be closed up.
[Modified by norvalwilhelm, 8:01 PM 5/6/2003]
Old May 6, 2003 | 10:46 PM
79corvette's Avatar
79corvette
Default Re: backfire on deceleration (norvalwilhelm)
I was driving one night, and revved my engine to scare off the ricers and they told me I had flames coming out that back :reddevil (actually i shouldn't be proud of that), guess I now know why. What are transfer slots and how can I close them up. I have the service manual, are there any good books that someone can recomend for this procedure?
Old May 6, 2003 | 11:00 PM
Black Snowman's Avatar
Black Snowman
Might try these:
http://www.amazon.com/exec/obidos/se...447772-6765620
Old May 7, 2003 | 06:43 PM
Rockn-Roll's Avatar
Rockn-Roll
I was getting the popping sounds and some backfire out the exhaust until I put in some new exhaust donuts and tightened up the exhaust pipe flange to exhaust manifold bolts...one of them broke and I had to have it removed. It's find now...I get a little rumble when I close down the throttle, but it's under control now...and actually, I kind of like that sound!
Old May 8, 2003 | 11:09 AM
Surfer69's Avatar
Surfer69
My popping went away after re-tightening headers/gasket.
Old May 8, 2003 | 04:30 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: backfire on deceleration (Surfer69)
I had a similar problem a few years ago, kinda liked the sound however it means you motor is not running properly, I bought a new carb and the backfire went away :D
Old May 8, 2003 | 08:08 PM
79corvette's Avatar
79corvette
Default Re: backfire on deceleration (MotorHead)
I picked up the book that Black Snow recomened. Book seem very informative and now I'm begining to understand a carb. Now I'm gonna try and get the mixture more rich. Just need to read how to do that, metering rods I think.
To backfire on deceleration
