Air Brush for touch up?
Old May 7, 2003 | 03:12 PM
Calm Screamer2's Avatar
Calm Screamer2
Default Air Brush for touch up?
I'm not an expert with the paint thing. Did rough paint jobs on my everyday vehicles when needed, but I don't trust myself to do class job on the vette. My baby needs some paint attention in a few small areas. Instead of breaking out the big boy and possibly screwing it up...what about using an airbrush. I bought one 5 years ago for small woodworking projects (seems to work OK with thin coatings) and thought it might be beneficial for a touch-up job on the vette. Anybody use these?
Old May 7, 2003 | 05:14 PM
goofygrin's Avatar
goofygrin
Default Re: Air Brush for touch up? (Calm Screamer2)
The Infiniti dealer my wife got her car at uses an airbrush to "fix/fill" rock chips (smaller ones). The chip is still there, but not nearly as noticable and it won't rust as fast (not that that matters on the vette...)
Old May 7, 2003 | 05:21 PM
PyjamaSam's Avatar
PyjamaSam
From: At the end of 2 big long black marks on #2 Sideroad and Walkers Line.
I was thinking of using mine on my 2 saturns this summer. Both My wife and I have a few little dings on the plastic bumpers.
Hopefully it will work. But I won't know till I try.
chris.
Old May 7, 2003 | 05:53 PM
TJRed76's Avatar
TJRed76
Default Re: Air Brush for touch up? (PyjamaSam)
If you feather the paint chips with fine sandpaper so that the sharp edges don't show, I don't see where you would have any problem. It operates with the same principle just smaller volume.
Make sure your hand is moving when you press the button so that you don't get that parbell effect. You probably already know that however.
Good luck, let us know how it works out.
To Air Brush for touch up?
