T-Stat = Smoke
Old May 8, 2003 | 09:06 AM
69Sting's Avatar
69Sting
Default T-Stat = Smoke
I put in a 180 tstat per group recommendation. Although my gauge isn't really reading much higher, I am getting a noticible better burn in fuel and the motor warms up much faster.
Now the fun part. I go to take off across an intersection, just a nice fast take off with out dropping the clutch and I tach out in 1st go to 2nd and smoke just comes a rolling in my window and the intersection is filled with a white cloud and the smell of fresh burned rubber. First time I ever got the tires to smoke.
One thing bad, I only left one mark accross the 4 lanes. Aperently I don't have posse. Guess I better burn the rest of these tires up before I put my new ones on.
I still have the old carb on, the Holly 650dp is being rebuilt currently. Should be on next week.
Just an fyi I have 336 rears.
:cheers: :cheers: :cheers:
Old May 8, 2003 | 10:43 AM
Fevre's Avatar
Fevre
Default Re: T-Stat = Smoke (69Sting)
Nice ride! :thumbs:
Those keystones rims? Always liked the black insets.
[Modified by Fevre, 9:45 AM 5/8/2003]
Old May 8, 2003 | 11:33 AM
69Sting's Avatar
69Sting
Default Re: T-Stat = Smoke (Fevre)
Yes, they are Keystones :cool:
Old May 8, 2003 | 11:36 AM
PatsLs1vette's Avatar
PatsLs1vette
you might want to put fresh fluid in the rear with an additive to get the posi working again.
Old May 8, 2003 | 12:02 PM
69Sting's Avatar
69Sting
Default Re: T-Stat = Smoke (patsnitrovette)
What would you recomend for fluid and additive?
Old May 8, 2003 | 12:41 PM
desi's Avatar
desi
Any 80W90 rear diff fluid. And GM Posi additive (4 oz.) costs around 7 bucks.
Good luck.
I am doing mine soon too.... :party:
Old May 8, 2003 | 01:44 PM
vettfixr's Avatar
vettfixr
Default Re: T-Stat = Smoke (desi)
:iagree: And after you put it in find an empty parking lot and run the car in circles at low speed to work it in. Alternate your circles (clockwise/counterclockwise) and don't be surprised if you hear a few clunks as things start to loosen.
Old May 8, 2003 | 01:58 PM
PatsLs1vette
Default Re: T-Stat = Smoke (vettfixr)
yeah what those guys said :iagree: :withstupid:
Old May 8, 2003 | 02:32 PM
Fevre's Avatar
Fevre
A little :confused: , seems if you are leaving only one mark your clutch pack might be gone. Now if you where leaving two marks and getting 'clutch chatter' around corners then I would think a fluid change might help. But since your posi isn't catching I don't think fluid is going to do much unless the fluid is the consistency of grease and not allowing friction in the clutch pack. :confused:
Old May 8, 2003 | 03:11 PM
Neo Fender's Avatar
Neo Fender
I'm sure someone will jump in if I'm mistaken but I believe positraction (limited slip) did not became standard until the 1970 model year.
To T-Stat = Smoke
