Has anyone repaired urethane bumpers?
Old May 8, 2003 | 02:23 PM
Guest
Guest
Posts: n/a
Default Has anyone repaired urethane bumpers?
Since a paint job several years ago my 74 has had accidents to both front and rear bumpers. A hole in the front and cracks in the rear. Can these be repaired with a good results or do I have to go with replacement bumpers? Thanks for any information you can give me. :confused:
Old May 8, 2003 | 02:32 PM
Missileman's Avatar
Missileman
Default Re: Has anyone repaired urethane bumpers? (T-Top Tom 1)
If the damage is small enough, Loctite makes a two-part flexible epoxy repair kit for urethane bumper covers. The cost is low (less than $10) and it works quite well if you take your time. Just follow the directions.
Old May 8, 2003 | 02:35 PM
Fevre's Avatar
Fevre
If your bubmer is in good cond then it might work but if yours is like mine, brittle, then I would not waste the time or effort. Had a guy who swares by the fix tell me to try it but I just think in the long run the patch will work for that area but the rest of the bumper will look like :U .
J R C's Avatar
J R C
Default Re: Has anyone repaired urethane bumpers? (Missileman)
You'll find lots of discussions in the archives ... here is one that includes a write up about repairing the bumpers
http://forums.corvetteforum.com/zerothread?id=171428
To Has anyone repaired urethane bumpers?
