Water Pump Ticking
Old May 8, 2003 | 10:29 PM
Dk Met Grn 80 L82's Avatar
Dk Met Grn 80 L82
Default Water Pump Ticking
Starting to get hot out now everyday. Noticed that when I turn on my undercharged AC system I am getting a sporatic tick sound near the water pump and also the engine temp is running 20-30 degrees hotter when the AC comp is on. I felt the upper hose, it is red hot but I can squeeze it pretty easy. Is this a sign the water pump is going or is this normal?
Old May 8, 2003 | 10:45 PM
ORVette's Avatar
ORVette
Default Re: Water Pump Ticking (Dk Met Grn 80 L82)
Try taking a piece of rubber vacuum hose or fuel line and using it like a stethiscope. I was getting some "ticking" that I thought was my WP(not the same symptoms though), and it turned out to be my fuel pump. Hold the ends of the hose to your ear and the possibly offending part, and you'll be able to tell for sure where the noise is coming from.
Old May 8, 2003 | 11:26 PM
iniguy's Avatar
iniguy
im only guessing but it sounds to me like your timing chain is rubbing the inside of the cover. very common at over 50,000 miles
Old May 8, 2003 | 11:30 PM
Dk Met Grn 80 L82
Default Re: Water Pump Ticking (iniguy)
I only hear the tick sound when the AC is on. Extra load?
To Water Pump Ticking
