Torq Specs
Old May 9, 2003 | 05:27 PM
phxraptor's Avatar
phxraptor
Default Torq Specs
I will be installing a new VB&P 330# rear composite mono spring soon and need to know the torq specs for attaching it to the diff. I will be useing new spring plate kit and spring bolts. Thanks for the help. :cheers: :seeya
Old May 10, 2003 | 11:15 AM
don hall's Avatar
don hall
Default Re: Torq Specs (phxraptor)
37 foot pounds, with a note: "partially tighten the center plate first and then raise each end of the spring in turn and connect the link bolts". (But you already knew that)
