TPI on BB
Old May 10, 2003 | 10:39 AM
Yellow73BB's Avatar
Yellow73BB
Default TPI on BB
Has anyone tried putting a late model TPI intake manifold on a early Gen IV big block? And, will it fit under a stock '73 BB hood? I'm tired of messing with my Holley throttle body and want to convert to TPI.
Thanks for any help.
Old May 10, 2003 | 10:42 AM
nitrocharger's Avatar
nitrocharger
Default Re: TPI on BB (Yellow73BB)
I know Holley and Accel make BB TPI manifolds. You can get one of these and just use a stock wiring harness.
~Christian
[Modified by nitrocharger, 10:43 AM 5/10/2003]
Old May 10, 2003 | 02:19 PM
mrvette's Avatar
mrvette
Check out Edelbrock, they make a DPFI unit for a BB.....
it's not a tuned port thing though....I don't think you can use a TPI type unit on a BB, the ports just aren't big enough even IF you could make something up the design is not what you want....
GENE
Old May 10, 2003 | 03:47 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: TPI on BB (mrvette)
have you checked out speed and peformance http://www.hotrodlane.cc/bigblocktpi.html
http://www.arizonatpi.com/products/SuperRamBB.jpg
http://www.arizonatpi.com/products/Stealth.jpg
[Modified by patsnitrovette, 3:51 PM 5/10/2003]
Old May 10, 2003 | 04:19 PM
Yellow73BB's Avatar
Yellow73BB
I'm hoping not to spend too much money, so Accel, Holley, etc. are out of the question. I already have a computer to drive the thing, I just need the intake manifold and injectors. That is why I am thinking about the 90's Gen V TPI system. I can probably get a manifold at a junk yard for a few hundred dollars with injectors. I just wonder if it will fit under my hood.
Old May 10, 2003 | 04:41 PM
Tyler Townsley's Avatar
Tyler Townsley
Start with something llike this:
http://www.holley.com/HiOctn/ProdLin.../9901-209.html
then use this:
http://www.bgsoflex.com/megasquirt.html
EFI setup cost is $120 or so software is free as is advice. These efi setups are being used on everything from motorcycles to rotarys.
Other bits:
http://www.holley.com/HiOctn/ProdLin...IA/FMSFIA.html
Another hint is to use the c5 filter/pressure regulator setup, this way you can avoid having to run a return line from the front of the car. It works for a Z06 should be enough for a BB.
Tyler Townsley
[Modified by Tyler Townsley, 4:56 PM 5/10/2003]
Old May 10, 2003 | 05:19 PM
L79vette's Avatar
L79vette
Don't think there is such a thing as a factory big-block TPI. TBI, yes. There hasn't been a factory high performance big-block in many years. They are all big-torque-at-low-RPM towing beasts of burden.
Old May 10, 2003 | 05:32 PM
Fevre's Avatar
Fevre
Default Re: TPI on BB (L79vette)
Few ideas for ya:
My fav:
http://www.speartech.com/cep-bigblockpix.html
Old May 10, 2003 | 05:41 PM
69stingray's Avatar
69stingray
What did the 454SS truck have for an induction system? I thought it was a TBI system.....was the 454SS truck Chevy or GMC? I am having a mental block.
A big block with EFI would be awesome! :cool:
Old May 10, 2003 | 06:52 PM
mean8t's Avatar
mean8t
Default Re: TPI on BB (69stingray)
The 454SS's were TBI. There is no such thing as a TPI big block as L79vette said. TPI is a very perticular system, some people use TPI to refer to all factory MPFI fuel injection. TPI was used only on 85-92 Y & F body 5.0L and 5.7L, that is it.
Josh
Old May 10, 2003 | 07:00 PM
Stefan69's Avatar
Stefan69
Default Re: TPI on BB (Tyler Townsley)
WOW. I just read the MegaSquirt description. That sounds like my kind of thing. Anybody have any experience with it?
$150 for the EFI controller. $300 for a throttle body. $400 for a machined manifold. $100 for fuel pump. And another $300 or so for injectors. Puts you at what? ~$1350. Does that sound about right? Wouldn't be a TPI, but at least and MPFI. Anf for the price of GOOD Demon carb... SOunds definitely worth considering. ZWEDE- what do you say?
Prost:cheers:
Stefan
Old May 10, 2003 | 09:14 PM
Yellow73BB's Avatar
Yellow73BB
Although it is too expensive, this is what I was thinking of. Does anyone know who makes this?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2414531694
Old May 10, 2003 | 09:19 PM
Yellow73BB's Avatar
Yellow73BB
Tyler,
That megasquirt system looks cool, but it doesn't look like it controls the ignition. The computer I am using is the GM 1227747, commonly found on GM vans and pickups in the 89-92 time frame. There is lots of info on the internet on how to program this, and I actually had it working pretty well with my Holley 4 barrel throttle body until one of my injectors died. Holley doesn't make those old injectors anymore apparently, so I am looking for another solution.
The problem with most of the manifolds on the market that have injector bosses is that they are too high and won't fit under the hood of the vette.
I may just decide to weld in some bosses into my cast iron manifold, and use my Holley throttle body to let in air. Then, with my computer driving the injectors, I may be able to get there.
Old May 11, 2003 | 07:47 PM
75 BBC Stingray's Avatar
75 BBC Stingray
That is an Arizona Speed and Marine Unit. They are pretty expensive. They are the only real "tuned port" setup I've seen. Many others are more like a tunnel ram with a plenum on top. The intake runners are much longer on the Arizona Speed and Marine Unit. EFI is expensive, a "TPI" style of intake for a big block would be aftermarket or custom. Not a junkyard find (unless you get real lucky.)
I've heard the Accel unit (BBC SuperRam) has been discontinued. I've never seen the Holley version. I thought they only had a TPI style for the small block. Most common BBC stuff is TBI, or a carb-style throttle body and MPFI.
Old May 12, 2003 | 03:15 AM
Enkil's Avatar
Enkil
Default Re: TPI on BB (mean8t)
Josh
Correct, and not only that, but TPI sucks. Not to offend any of the people that have done a TPI conversion, but... it's probably one of the worst forms of fuel injection. Sure, it's a great, torque-y system, but it's not the cheapest or easiest to modify, and it has a huge wall right around 4500rpm. There are FAR better fuel injection systems out there, like the MPFI's you can buy out of Jegs and such.
Old May 12, 2003 | 11:58 AM
groovyjay's Avatar
groovyjay
I'm using Edelbrock's Multi Point EFI on my 454 LS6. Easy to install, easy to tune etc. I'm very pleased with it. :cheers:
Old May 12, 2003 | 01:51 PM
Fevre's Avatar
Fevre
Default Re: TPI on BB (Enkil)
Josh
When properly set up a tpi system can be an excellent choice for street use.
To TPI on BB
Old May 12, 2003 | 04:54 PM
mean8t's Avatar
mean8t
Default Re: TPI on BB (Fevre)
Josh
:iagree:
Just change the runners, base, and choose the right cam and you have a killer street setup.
Old May 12, 2003 | 05:05 PM
Stefan69's Avatar
Stefan69
Josh
Well, TPI means Tuned Port Injection. All that means it is a MPFI (Multi Port Fuel Injection) with 'tuned' runner lengths to give optimum performance in a specific RPM band. And no. TPI is typically the best you can have. The Z06 has a tuned port injection setup if I'm not mistaken...
Please tell me if I'm wrong. Always willing to learn.
Prost:cheers:
Stefan
Old May 12, 2003 | 06:42 PM
Fevre's Avatar
Fevre
Default Re: TPI on BB (Stefan69)
Stefan
I believe you are correct, the LS1 intake is a modified tpi. The tpi was really made to give torque to low end of the 5.0 since gm thought they where going to deep six the 350. But FI proved to breath new life into the 350 with increased gas mileage and lower emissions. THe LT1 was greatf or high end but lost a bit on the low end torque. The LS1 is kinda in the middle, shorter runners than the tpi for higher rpm's but longer than the LT1 for more low end torque.
And lets be honest, how often do you drive a street car above 5000 rpm's anyways? :confused: Plus the orig tpi just looks too :cool: compared to the LT1 and LS1.
[Modified by Fevre, 6:43 PM 5/12/2003]
