Edelbrock Carb ?
Old May 10, 2003 | 08:20 PM
Duke94's Avatar
Duke94
Default Edelbrock Carb ?
I have installed an Edelbrock 1400 carb on my 78'. I assume I need a vacuum advance port on the carb that has full vacuum at idle. Neither of the small front ports on the carb have vacuum at idle. Vacuum only when the throttle is opened. Where do I pick up the vacuum for distributor advance?
Old May 10, 2003 | 08:47 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Re: Edelbrock Carb ? (Duke94)
No, you do NOT use vacuum advance at idle. it HAS to be ported vacuum.
Old May 11, 2003 | 12:05 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Looking from the radiator, the left port is is ported for the distributor, the center is manifold vacuum for the PCV, the right side is manifold vacuum.
To Edelbrock Carb ?
