HELP!
Old May 11, 2003 | 12:33 AM
SizzleChest's Avatar
SizzleChest
Default HELP!
i just changed my timing chain and now when i start it up it won't fire. i'm sure i put the chain in the way it's supposed to go. i think it's something with the distributor but don't know exactly how to fix it. thanks!!
Old May 11, 2003 | 02:23 AM
wombvette's Avatar
wombvette
Default Re: HELP! (SizzleChest)
You need to go back to square one. Turn the engine to #1 TDC. Make absolutely sure that the valves are closed and there is compression on #1. Then look at the rotor and see where it is pointed. You will probably find that you have it off some. Set the pointer to #1 and make sure that the points are just opening at that point. That should do it.
Old May 11, 2003 | 03:05 PM
FeedVaal's Avatar
FeedVaal
Default Re: HELP! (wombvette)
Good advice. Also get a can of ether to insure it fires with the timing a litlle bit off. If you can get it to run its a lot easier to set the timing.
Old May 11, 2003 | 09:55 PM
SizzleChest
i must have the links on improperly on the cam. i cannot get it to fire at all. this sucks!
To HELP!
