I am changing the spark plugs and a couple of them are really stuck on there tight...I've been using Liquid Wrench liberally and still no budging...I've replaced 5 but have 3 to go (and 2 of the 3 have snapped in half still in the block!)...any advice on how to properly and safely remove these stuck spark plugs?:confused:
Re: Old Spark Plugs stuck...PLEASE HELP (78RedShark)
i always tap on the wrench to jar them loose. Sometimes i tap in the tightening direction for a few raps to jar it loose. Sounds bass-ackwards, but i've seen it work.
Re: Old Spark Plugs stuck...PLEASE HELP (Matt Gruber)
:iagree:
Sometimes all it takes is to get it to move, even if it's in the wrong direction.
Re: Old Spark Plugs stuck...PLEASE HELP (bluevetteman)
Make sure you have a GOOD six sided (not twelve) spark plug socket. Make certain that you get it on the plug perfectly square.
Very important!!
Use a breaker-bar socket wrench, or add an extension to your socket wrench (a one foot length of pipe) that will slip over the wrench handle for added leverage.
Re: Old Spark Plugs stuck...PLEASE HELP (my350tpi)
there's only so many four-letter words... :cuss
I've managed to get 2 of the 3 stuck plugs out...1 more to go! But it's a real bugger, I've tried four times today...someone mentioned using a mini-propane torch to heat it up...is this a good idea? :confused:
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
The only help I could give would be to use a cheater or breaker bar to get more leverage on the plug. Also when you go back, get some NEVER SEIZE so next time this job will be easier.
