1972 Muncie 4 Speed
Old May 11, 2003 | 01:52 PM
Stratos's Avatar
Stratos
Default 1972 Muncie 4 Speed
Question, on my 72, I have a Muncie M21, I have a gear oil leak from just below the front shifter fork (side access plate) towards the bell housing. There is what looks like a 3/4 nut just below the shifter arm, in the middle of the nut there appears to be a nylon insert. is this a vent? Can I just pull it, clean it or do I have to replace it?
Old May 11, 2003 | 04:04 PM
Gordonm's Avatar
Gordonm
Default Re: 1972 Muncie 4 Speed (Stratos)
It is a switch. It tells the primative emission system that the car is in 4th gear and to allow the vacuum advance to allow full vacuum, if the switch on the intake is still there (most likely gone). You can remove this switch and clean and try to seal it up.
Old May 11, 2003 | 04:16 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: 1972 Muncie 4 Speed (Gordonm)
I always thougt that this "nut" was the backup light switch..If it isnt,then where is it? :smash: :cheers:
Old May 11, 2003 | 04:26 PM
Rockn-Roll's Avatar
Rockn-Roll
Default Re: 1972 Muncie 4 Speed (BB wowbagger)
BB wowbagger said: I always thougt that this "nut" was the backup light switch..If it isnt,then where is it?
It's toward the back...the early muncies didn't have an integrated reverse switch, so the reverse switch was mounted on a bracket and attached using the side cover bolts...a push rod connects the switch to the reverse lever.
You might want to get a plug for that Stratos...you can use some permatex part B on the threads if you want to just find a bolt.
To 1972 Muncie 4 Speed
