Aluminum Water Pump Question
Old May 11, 2003 | 04:41 PM
jerryjfunk's Avatar
jerryjfunk
Default Aluminum Water Pump Question
Hey guys,
I have two aluminum SBC water pumps. They're both short neck, so I can use either one. One is used, and has a larger shaft than the other one, which is new. Does the shaft size make a big difference, or should I just use the new one?
Thanks,
Jerry
Old May 11, 2003 | 04:57 PM
1979toy's Avatar
1979toy
Default Re: Aluminum Water Pump Question (jerryjfunk)
Your pulleys should have a hole sized for a 3/4th inch diameter shaft. You will not be happy with the results of using a 5/8ths shaft with a 3/4 inch pulley.
Don't forget that small block Corvette water pumps are a differnt length from a standard short water pump
[Modified by 1979toy, 3:58 PM 5/11/2003]
Old May 12, 2003 | 01:50 PM
jerryjfunk's Avatar
jerryjfunk
Default Re: Aluminum Water Pump Question (1979toy)
Thanks! I didn't even look at the pulley to see that it's made for the larger shaft.
Thanks again,
Jerry
Old May 12, 2003 | 03:15 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Don't forget that small block Corvette water pumps are a differnt length from a standard short water pump[Modified by 1979toy, 3:58 PM 5/11/2003]
So, if I just ordered a standard, short pump, what do I need to do to make it a short "corvette" pump?
To Aluminum Water Pump Question
