Need help identifying engine block
Old May 12, 2003 | 05:25 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Default Need help identifying engine block
The numbers stamped on the front of the block near the passenger side head is V02071KY.
Thanks for any help Neal
Old May 12, 2003 | 05:30 PM
Tom73's Avatar
Tom73
Default Re: Need help identifying engine block (chevymans 77)
V02071KY
V=Flint engine plant
0207=assembly date, Feb 7th
1KY=usage suffix, should be three letters.
Cannot find an IKY or JKY or LKY. Can you check the number to confirm what the digit befor the K is?
Could it be TKY? If so, the TKY suffix was used three time.
1974 350/160hp truck engine
1978 350/165hp truck engine (LS9)
1980 350/165hp truck engine (LS9)
tom...
[Modified by Tom73, 4:35 PM 5/12/2003]
Old May 12, 2003 | 05:52 PM
chevymans 77
Default Re: Need help identifying engine block (Tom73)
Thanks Tom more then likley it is TKY. The carb also looks like a GMC late 70's early 80's truck carb. lools like thats what it is. :)
To Need help identifying engine block
