My car was painted with polyurethane four years ago. The guy painted the door jambs but painted over the factory installed sticker on the driver's door. Is there anyway to remove the paint without damaging the factory ID sticker? The paint will not chip off (i tried).
Re: A question about polyurethane paint. (Rick Church)
Poly paint is pretty tuff, but you might try this. Chances are if he didn't bother to tape off the decal he probably didn't wipe things down very well be for he painted the car. I would take a q-tip and some laquer thinner. Soak the tip and start dapping a spot and rub ever so gently. You may have to try the same spot over and over, but don't rub. Just try and soften the paint and scrape a little. If you rub w/thinner on the decal it will be wiped clean of everything. Becareful and if thinner won't work try a reducer. Hold a rag under your work area so you don't soak the rest of the jamb area. good luck
