Question??????on c3
Old May 14, 2003 | 11:58 AM
tabbruzz's Avatar
tabbruzz
Default Question??????on c3
Just got the car. When you punch it from a roll it has the tendancy to jump to the left a bit. Any ideas on what would cause this, bad alignment, bad suspension bushings, etc. Or is this kinda normal ?????
Thanks guys........
Old May 14, 2003 | 12:04 PM
77Dream's Avatar
77Dream
Default Re: Question??????on c3 (tabbruzz)
Could be any of those, I would take it to a good tire shop. They can check alighnment and let you know of anything thats out-a-whack. But if makes you feel any better, mine likes to pull to the left all the time. My problem is brake pad/rotor wear. My left front brake grips allot more than the right.
:cheers:
Old May 14, 2003 | 12:17 PM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Broken motor mount maybe? :confused:
Old May 14, 2003 | 12:24 PM
isosceles's Avatar
isosceles
I'd suspect Trailing arm bushings :skep:
Old May 14, 2003 | 12:29 PM
groovyjay's Avatar
groovyjay
There's many issues that might cause the problem. I'd say take a good look at your suspension, tires and wheels to find the problem. :cheers:
Old May 14, 2003 | 01:23 PM
tabbruzz's Avatar
tabbruzz
Default Re: Question??????on c3 (groovyjay)
Thanks everybody......I quess this isn't normal for these cars...
Old May 14, 2003 | 01:50 PM
TedH's Avatar
TedH
Correct. Normal is the car squats, hooks/launches hard and lays two long black patches of rubber with lots of smoking and screaming tires...
you get the idea... :smash: :smash: :D :D
Old May 14, 2003 | 03:17 PM
tabbruzz's Avatar
tabbruzz
Default Re: Question??????on c3 (TedH)
Well it does squat so that's good.....Now if I could keep it straight...
Old May 14, 2003 | 03:21 PM
mayberg's Avatar
mayberg
I thought mine was trailing arm bushings - turned out to be strut rod bushings and excessive play in rear bearing.
To Question??????on c3
