rear brakes
Old May 16, 2003 | 08:24 PM
jetech's Avatar
jetech
Default rear brakes
Is there any problem replacing just the rear brakes with stainless calipers for now and then change the front over later. My front brakes work fine but one rear wont work at all. Thanks for the help. :cheers:
Old May 16, 2003 | 08:46 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Default Re: rear brakes (jetech)
i wouldn't think so. :)
Old May 16, 2003 | 08:52 PM
Rockn-Roll's Avatar
Rockn-Roll
That would be fine. But, make sure you bleed the fronts after bleeding the rear, cause opening a line will get air in the system including the fronts.
Old May 16, 2003 | 11:33 PM
flynhi's Avatar
flynhi
Be sure to use O rings in the rear. Air pumping from rotor run out is more severe in the rear and the use of o rings is more important to keep air out of your system.
I prefer O rings and alum pistons from Zero Tolerance although many have had good luck with Vette Brakes O rings.
To rear brakes
